Old 05-20-2006, 01:54 AM   #1
Green Monster
Green Monster's Avatar
Windows don't roll up and down smooth
What's the deal? Something bent of out of alignment? Anyone have this problem? The crank is really hard to turn at the 6 o'clock position of the window crank. Passenger side is even worse.
Green Monster is offline   Reply With Quote
Old 05-20-2006, 01:58 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Windows don't roll up and down smooth
What is the condition of the window guides? If the felt in the tracks is in bad shape it can make it hard to roll the windows up/down.
I'd pop the door panels and loop the mechanisms up really well to see if that helps.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-20-2006, 02:36 AM   #3
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
LUBE,LUBE,AND MORE LUBE!!!!!!!!!!!!!!!
HEY NOW!
donkey69 is offline   Reply With Quote
Old 05-20-2006, 02:50 AM   #4
Green Monster
Felt is perfect. Lubed once before. Guess I will lube again and see. I I'll try some anti sieze thread compound.
Old 05-20-2006, 03:59 AM   #5
DEFIANT NCC-74205
DEFIANT NCC-74205's Avatar
Anti seize gets a bit stiff in the winter. Molygraphite is super slick all year long. Also silicone is safe to spray down in those guides. Won't hurt the felts. Probably got lots of that desert dust in there. Make sure you get every possible friction point. If that doesn't help, it might be time for new regulators. I think they are about $40 from LMC, but might be cheaper elsewhere. Good luck!!
To go with honor and courage, a far and wonderous distance
DEFIANT NCC-74205 is offline   Reply With Quote
Old 05-20-2006, 07:41 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Agreeeed
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-20-2006, 09:07 AM   #7
makovai
makovai's Avatar
i have to grab the top of my window to roll it up or down. But i know all my stuff is worn out.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 05-20-2006, 09:08 AM   #8
72CSTC5
72CSTC5's Avatar
Just a thought, sometimes in the past when I have worked on old cars rust will build up and swell at the pivot point of the regulator. Take them out and hit them with a punch and a hammer at the rivet point and they should loosen up some. Try it, it just might work for you and lube while you are in there.
72CSTC5 is offline   Reply With Quote
Old 05-20-2006, 10:30 AM   #9
Green Monster
If the lube and giving the pivot points a whack does not work, then I'll look at replacing the regulators. Thanks guys.
Old 05-20-2006, 12:23 PM   #10
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
If you find the answer post it please because I have the exact same problem.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 05-21-2006, 12:03 AM   #11
Medicanman71
Medicanman71's Avatar
Arent you supposed to use one hand to help push/pull the window up/down when you use them?!?!?!?
But really, i just roll them down and leave them that way once it's nice
Problem solved.
Medicanman71 is offline   Reply With Quote
Old 05-21-2006, 09:48 AM   #12
Jimmy72custom
Jimmy72custom's Avatar
I spray my window tracks with silicone spray. I converted my windows to electric and the silicone keeps them moving smooth. I use it on my other vehicles also. I have found that if you spray down the door seals it also keeps them from freezing the door closed during the winter.
Jimmy72custom is offline   Reply With Quote
Old 05-21-2006, 11:21 AM   #13
jakeslim
Premium Level Member
jakeslim's Avatar
I had/have same problem. Both windows were hard to roll up and down.
*For the Drivers side, I changed the regulator with an NOS one. I also changed all of the tracking and door rubber/felt. This window almost rolls itself up it is so easy.
For the passenger side, I did not change the regulator, just cleaned and lubed it up with plenty of grease. I did change the tracking and door rubber/felt. Although easier to open, it is not as easy as with the new regulator.
So, your best bet if you are looking for easy rolling is to change the regulators. Its is not difficult, just need to take your time.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 05-21-2006, 11:40 AM   #14
bouncytruck
SKINNY TIRES RULE!
Jimmy72custom What kind of Silicone did you use? Does it collect dirt & dust?
jakeslim Where did you get the NOS regulator?
bouncytruck 1972 K5
Old 05-21-2006, 12:32 PM   #15
jakeslim
jakeslim's Avatar
bouncy,
I was lucky, when I bought my blazer it came with the buy. The PO had bought it several years prior, but never changed it out.
I'm not sure if you can get them anymore...don't think so. I've never seen one on ebay..well in the last couple of years or so.
Maybe someone else can chime in on availability.
Old 05-21-2006, 08:55 PM   #16
Green Monster
Thank you for the info Jakeslim.
Old 05-21-2006, 10:05 PM   #17
Jimmy72custom
Bouncytruck, I just buy the cheapest spray silicone lubricant I can find. I live on a dirt road and have not had an excesive dust problem. My friend tried it on his Ford (excuse my language) because he was popping the electric window breaker. Cured the problem.
Old 05-22-2006, 03:40 PM   #18
Patch
Patch's Avatar
Mine has that problem too...I notice my door allignment was off and the top was pushing the upper part of the door out of whack...the spot weld for the door post was cracked.....once I pushed the post back in...window rolled up and down just fine.....I'm sure there's worn out stuff too.
Patch
Patch is offline   Reply With Quote
Old 05-22-2006, 08:26 PM   #19
RANDY COX
RANDY COX's Avatar
me too
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
