Old 05-20-2006, 09:52 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
What I got done today
Well, my water neck has been leaking for quite some time and my temp gauge hasn't worked since I got the truck so I finally broke down and figured I'd fix them both. I've had a new chrome Mr. Gasket water neck for about 2 months now and the laziness in me finally subsided in a fit of boredom today. I figured I'd flush the coolant system while I was at it so after a quick run to the parts store in my daily I was back at the house and into my day's project. I drained the radiator in the garage (kept the mess to a minimum thanks to a 6 gal. drain pan) and then unbolted the water neck and sending unit. Replaced with the new stuff and pushed the truck back out of the garage and into the driveway to flush the system out. It was pretty grimy for a little bit, then turned a little milky. I wasn't expecting that. But then it cleared right up and was ready to be closed back up and filled with fresh fluid. While I was running it with the water on I noticed my temp gauge was working Sweet! Filled it back up with fluid/water and ran it, then topped off and I was done. Took a lot less time than I thought. Tomorrow it's a fresh oil change and then I get to order all my goodies so I can get the sucker bagged!!!
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 05-20-2006, 10:15 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: What I got done today
ok i will say it...good job
rage'nrat638 is offline   Reply With Quote
Old 05-20-2006, 11:13 PM   #3
TugOwar
Another job well done! Good going.
TugOwar is offline   Reply With Quote
Old 05-21-2006, 04:57 AM   #4
local13hutch
MEMBER
local13hutch's Avatar
Well I went out and stared at my truck today threatening to do something. Out of the five fixes on my list I did the smallest. headlight switch. Because I thought it had a short changed the switch still have the short......You did better than I did.
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
