05-21-2006, 11:11 PM | #101 |
Re: beating this question to death! LT1/4L60E
Great thread guys. Sounds like the work involved in this conversion is mind boggling, but I'm sure it's worth it. A reliable engine with 300hp and decent fuel consumption too!!
I've driven the LT1/4L60E police package for many years (when they still made them) and they kick some serious a$$!! They take a licking and keep on tickin' too. Keep at it guys, don't lose the faith. Please update on your progress. I'll be checking this post often.
If you keep and open mind you never know what might drop in. 1970 Chev C10 SWB, "250 turbo thrift" |
05-21-2006, 11:21 PM | #102 | |
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-22-2006, 07:41 AM | #103 |
Yes it will work with red coolant. I have been running that setup for over a year. I do have a electric fan setup with a electrical thermostat for the fan. Wootdog
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
05-22-2006, 07:48 AM | #104 |
The reason I didnt use the factory C-10 radiator was because of radiator inlet and outlet sizes. You have to Jerry rig the hoses. There is also a steam pipe setup for the back of the heads. If you use the camaro setup, the hoses fit correctly and one of them actually has another smaller hose coming off of it for the connection to the rear of the engine. Wootdog.
05-22-2006, 12:30 PM | #105 |
chevelito
damn...wootdog beat me to it. the c10 radiator is IIRC 1 1/2" while the LT1 has the 1 1/4" or 1" inlet/outlet.
wootdog...did you use the 3 row brackets?
New deadline...when my son can drive. Aloha from Honolulu, HI Last edited by jay-dawg; 05-22-2006 at 01:06 PM. |
06-11-2006, 11:58 AM | #106 |
Junior Member
Here is a website where you can get the ac relocation brackets for the lt1's. I used this setup with out notching the frame. www.bowersrodshop.com/info_pulley.htm
07-31-2006, 09:23 PM | #107 |
Are you sending out your harness to get done?
08-01-2006, 03:54 PM | #108 | |
Junior Member
08-01-2006, 05:15 PM | #109 |
Where did you send your harness pdr?
Shifty, I could use the part #s for that fuel reg and filter if you still have them handy. Also, im going with a poly tank and external pump for $$$ reasons...any suggestions?
1986 C10 - LWB, 305/700r4, posi, vortec heads |
08-01-2006, 08:36 PM | #110 | |
Junior Member
02-23-2007, 01:26 AM | #111 |
What is everyone using for headers with the LT1 swap?
02-23-2007, 02:21 AM | #112 |
Im running andersons cc11dp headers.
02-23-2007, 11:02 AM | #113 |
www.loweredd.com
I used Hedman shorties for our trucks. Worked great!
02-23-2007, 11:32 AM | #114 |
Right on, any idea on a model number? I will be looking in the meantime. Thx!
02-23-2007, 04:09 PM | #115 |
I am using Street & Performance headers
02-23-2007, 07:41 PM | #116 |
Junior Member
I am using the Hooker Super Comps.
1970 C-10 Fleet Side Gen IV 6.0 with 4L80E |
02-23-2007, 09:20 PM | #117 |
Dang Fast...now ive got a severe case of engine envy! Makes my LT1 look like a soup sandwich. Do you have a list of all the stuff you got from S&P with part numbers?
02-27-2007, 05:55 PM | #118 |
I just bought my lt1.
03-09-2007, 11:07 AM | #119 |
Ok, im running out of funds for the LT1 project so I am going low cost on the harness and PCM work. I just dropped $285 with Jeff from PCMAmerica. Ive heard mixed reviews but he seems like a good fella so im going to give him a try and let you guys know how it works out.
If I can scrape together the funds my next purchase is going to be headers. My only problem is all the ones I see in the catalogs are for the F or Y bodies and only 2 or 3 are listed for Impala/Caprice which is what I have. I would think that any D-port headers would suffice but im having problems find them for under $350. There is no way I can afford ceramic coated versions so im going plain Jane painted headers. Whats the difference between long/mid/short tube headers? Is one better than the others?
03-09-2007, 01:01 PM | #120 |
Long tube are the best for performance and short are the best for fit most of the time. You can use any small block headers, you will just have to weld in bungs for the O2 sensors.
1972 Blazer body...need to get a thread started for the rest of the story |
03-09-2007, 04:23 PM | #121 | |
Junior Member
Only one word of wisdom from me. It is always best whendoing a project like that to take before and after pictures, and any other info you have and send it to JoeFrus@americanthunderbike.org May not make the job go well, but it could help me when I do the swap myself. Last edited by Cochise; 03-09-2007 at 04:27 PM. Reason: forgot to quote |
03-09-2007, 05:22 PM | #122 |
Junior Member
I just realized this thread has been going on since 2003.
03-12-2007, 04:10 AM | #123 |
How did most of your guys resolved the AC Hitting the frame problem?
03-12-2007, 12:25 PM | #124 |
Well I think there are 3 options...relocate the comp with the corvette setup, delete the A/C and run the delete pulley OR notch the frame for the belt. Since I live in the south and cant afford the vette setup im going to be notching.
03-12-2007, 01:35 PM | #125 |
When running the AC delete does the frame still has too be nontch? How much has to be notch? any body has pics?
