05-23-2006, 01:12 AM | #1 |
Active Member
Rally Wheel Widening
Just curious where i can get my Truck Rally Wheels widened or buy some that are already done for the 6 lug pattern. I put 35x12.5x15 tires on my 8 inch rims and they just look wrong. I need them to be 10" for them to spread out and look right. What have you guys done? Any idea what they might cost?
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
05-23-2006, 07:12 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Rally Wheel Widening
Did a quick search...here are a few I found.
http://www.stocktonwheel.com/wheel_widening.htm Looks like these guys have what you want in stock. http://www.stocktonwheel.com/light_truck_wheels.htm http://www.weldcraftwheels.com/ http://www.internetalternatives.com/wshoppe/wwiden.htm http://www.winnipegwheelworks.ca/services.html
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 05-23-2006 at 07:20 AM. |
05-23-2006, 07:58 AM | #3 |
If it looks wrong to you, then by all means get them widened but 12.5's are run on 8" wheels all the time.
Fact is, if you wheel with it, the tire will protect those rims better with an 8" than a 10" wide wheel. Consider this also, with a 10" wheel and 12.5's you'll BARELY fit inside the wheel wells on a car trailer. (don't know if you trailer) but it's good info to ponder on. Watch the tire pressure (not to high) so you don't wear the centers and you'll be all set running that combo. JMO. |
05-23-2006, 04:10 PM | #4 |
I just put 35s on my 8" wheels last week and think they look great.
05-23-2006, 04:22 PM | #5 | |
05-23-2006, 04:42 PM | #6 |
The LuvShack Garage
Mine are on 8' also, but 10's look wicked, member here w/ 10's
on a Orange / White blazer and they do look more filled out
05-23-2006, 05:18 PM | #7 |
Active Member
Thanks for the help guys. I just like my tires to look more filled out like they are suposed to be. A buddy of mine has 15x10 truck rally wheels on his 72 pickup. Same tire and wheel setup as mine, but his tires actually look 1 1/2 inches wider and more symentrical looking. He got his at a swap meet so i knew it could be done, but was not sure where. Looks like i will be adding that to the list of things to do.
05-23-2006, 05:21 PM | #8 |
The LuvShack Garage
Stockton widens them, and sells them in a 15 x 10 rally
