Old 05-23-2006, 04:38 PM   #1
truckdude239
truckdude239's Avatar
they dont fit
got my brake lines from inline tube today got to putting them on the truck and the line on the rear end dont fit. got inline tube trying to figure it out they said the rearend probley was changed any ideas of how to tell it it was everything under looks like its stock
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-23-2006, 04:40 PM   #2
truckdude239
Re: they dont fit
the top picturte is the tube for the passager side and the bottom picture is the tube for the driver side which is too long and the passger side is too
short
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 05:18 PM   #3
cdowns
cdowns's Avatar
Re: they dont fit
71 had a shorter pass side line because the rubber hose came from the front of the axel to the axel tube and 72 came from the rear closer to the center of the axel assy
Old 05-23-2006, 05:24 PM   #4
truckdude239
Re: they dont fit
this is the rearend that is in the truck i circled with the ruber hose mounts too
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 06:38 PM   #5
smbrouss70
smbrouss70's Avatar
Re: they dont fit
On my 70 the rubber brake hose mounted where I circled. I used inline tube also, and they fit great on mine. Apparently the hose mounted in different spots depending on year.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-23-2006, 08:53 PM   #6
truckdude239
Re: they dont fit
1anyone know what year this rearend is out of? or something close
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 08:59 PM   #7
mbgmike
Re: they dont fit
Inline tube generally does a good job. Their main competitor I would never recommend. I waited 3 months after 6 calls I get them and they didn't even include enough to go from the front to the back plus most of it was not pre-bent like i paid for. I will bend my own from now on.
mbgmike is offline   Reply With Quote
Old 05-23-2006, 09:17 PM   #8
truckdude239
Re: they dont fit
the products i got where high tech and done right the front lines and the main line that runs down the frame fit well just these 2 rear lines i need to find out what rearend this truck has in it so i can send these 2 back and get the proper lines
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 09:55 PM   #9
Re: they dont fit
I don't know what rear end for sure your's is, but my 82 C10 6 poppoer/T350 had the readr lines juction block where yours is. I have 4 or 5 axles at my place now for 69-72, and they all have it in the positions on the passenger side axle tube like in the second shot. So my guess would be yours was swapped out with a later 70's style rear end.
Old 05-23-2006, 10:00 PM   #10
truckdude239
Re: they dont fit
okay cool i think i'll send the the brake lines i got now and they can remake the ones i got
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 10:06 PM   #11
cdowns
cdowns's Avatar
Re: they dont fit
or you could grind the tab off and weld it to the position where it will work// should take about 10minutes and no postage
Old 05-23-2006, 10:08 PM   #12
truckdude239
Re: they dont fit
umm that could mean i would need a welder can i borrow one? lol j/k
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 10:08 PM   #13
truckdude239
Re: they dont fit
i might look into that i have some friends
David fuller
2000 Tahoe 5.3l 378
Old 05-23-2006, 11:19 PM   #14
roughedup72
roughedup72's Avatar
Re: they dont fit
I just changed the rearend in my 72 this weakend from my parts truck which is also a 72 and both of them were where you circled in your first pic. I say its a 72.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 05-23-2006, 11:21 PM   #15
qksilver
Re: they dont fit
Hey if you get to borrow a welder bring down here. I will pay for gas!
qksilver is offline   Reply With Quote
Old 05-23-2006, 11:34 PM   #16
truckdude239
Re: they dont fit
lol i going to try and get the right lines for the rearend before i go cutting and welding even if its an easier way out
David fuller
2000 Tahoe 5.3l 378
Old 05-24-2006, 01:10 AM   #17
4x4Poet
Re: they dont fit
My 72 C10 coil spring burb also has the T junction for the brake hose on top of the pumpkin, not on the axle tube. Maybe your '71 truck has an early install of a '72 axle or a '72 axle swapped in.
Definitely return the new and send in the old for them to copy. Be sure to insist that they send back the old with the new to check how well they matched the new lines.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-24-2006, 07:29 PM   #18
truckdude239
Re: they dont fit
well i sent the rar lines back to inline tube along with the oringals and they are going to make me a copy of the lines and get me on the road again
David fuller
2000 Tahoe 5.3l 378
