1979 c10 power brake booster in 69 c10?
Can I use a 79 power brake booster/master cylinder from a 79 c10 in my 69 c10 without any modification? Are the pushrod lengths different or is the master cylinder different for 73-87 trucks?
Thanx in advance Dano
![]() ![]() It ain't yours, if you didn't build it! |
![]() Join Date: Feb 2004
Re: 1979 c10 power brake booster in 69 c10?
Here is a link for a 78 once Josh gets it working. If you have column shift, ponder before you modify. Yes pushrod lengths from the booster to the pedal arm are different. Use the 79 MC with the 79 booster -- brake line connections should work.
Please help Josh. http://67-72chevytrucks.com/vboard/s...d.php?t=165344 |
I'm going to go for it this weekend. Why should I "ponder" if I have column shift?
Dano
![]() ![]() Join Date: Jul 2002
Looks like it wioll hit the booster when you try to shift.
I see the link is not working yet. If you modify the mount for a level fit as Palf70Step says your lower shifting arm may hit the booster. All pics but last one is a 79 booster modified. Last pic is a modified Fiero. Goodluck.
Please keep us updated as I would like to do the same mod with the same parts...Pis are nice
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
If you use the same hole on the 69 brake arm with the non-fulcrum boosters you will lose some pedal --still brakes satisfactorily tho. To get some pedal back --drill a new hole about 3/8" lower (remove arm is the easiest way). The rod length from the firewall mount to the brake arm is about 8.5". Adjustable is the best way --- do not preload the booster.
