Old 05-24-2006, 07:35 PM   #1
rage'nrat638
rage'nrat638's Avatar
Thumbs up thank you Jesus, thank you lord
o boy...just when i was wondering if the guy's upstairs had forgotten about me...BOOM....
BEEN HAVING SOME BAD LUCK AS OF LATE..
well any way, i was checking the oil and adding some on the 69 and then started it up. noticed the alternator drivers side mounted sb style.
shaking as normal for years. looked at the bolts.. ones half out. go to tighten !!!
nope its broken about 1/8 inch in the head
well this is when my stomach sunk. been having this feeling alot as of late.
pulled on the bolt, the broken ends all rusty and smashed.
been broken for some time..well there's only two bolts holding this thing as we all know, how the whole thing had not just fallen off, and caused all kinds of damage no one knows.
well if you look at where these bolt holes are..it's not good..
i say a little prayer.. cut down a drill bit and use the air drill and drilled a hole
in the bolt.. out it came with the easy out..
this could have been real ugly,, real fast.
said another prayer..
why do i think god blessed me
was able and blessed with the tools to drill out with out removing the fan or anything.
the alt. had not fallen off and caused tons of damage
the bolt backed right out..
i had new bolts on hand to replace the old ones with.
it was a 15 min. repair
OK i am done..i just want to say sometimes we take the little things for granted..included a couple pictures to show...god bless mark
rage'nrat638 is offline   Reply With Quote
Old 05-24-2006, 08:31 PM   #2
mrein3
mrein3's Avatar
Re: thank you Jesus, thank you lord
Speaking from experience, I can say that if that bolt would have broke off, nothing too damaging would have happened. Ask me how I know.
I bought my truck in 1994. It is pure mutt. Since day one I've been putting new bolts in there after one breaks off.
I bought a different set of mounts for the alternator. Bolts still broke.
New engine. Still broke. New grade 8 hardware. Still broke. New crank pulley. Still broke.
Now finally, after breaking another one on the way to a fishing club tournament one year ago, I replaced the water pump pulley and crank pulleys with known good pulleys from known 67-72 sources. I'm still knocking on wood but so far so good. The shake you talk about is gone. I MAY have finally took that bit of cowboy engineering out. (The truck was "assembled" in Wyoming with numerous years of trucks supplying parts)
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-24-2006, 08:31 PM   #3
Alvin
Never Done?
Alvin's Avatar
WOW, I'd say He was definitely looking out for ya on that one! Glad to see it worked out so well!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 05-24-2006, 08:39 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I had one snap once, turned out the previouse owner installed a way too short bolt in there... it was in the head about 4 or 5 threads. I got lucky on that one... more so than you.
Broke while I was on the road, smelled coolant, looked down, guage was reading melt down, so I pulled off the freeway right at the front gate at Ft Hood, opened the hood and saw exactly what happened... and there was some sticking out of the head! I turned it out with my bare hand! Just happened to have a 9/16 wrench in the cab, and found a longer bolt in the bed. I was back on the road in 15 min.
Wasn't even late for work.
Old 05-24-2006, 09:04 PM   #5
krue
Designated A-hole!
krue's Avatar
The bolt on the outside on mine was broke, the one on the middle was stripped out (bad enough that I didn't need a drill to put a helicoil in it ). I guess the belt tension was the only thing holding mine in. I got the broke one out with a left handed drill bit (yes it did work in my case).
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-25-2006, 12:14 AM   #6
Hart_Rod
Hart_Rod's Avatar
I had the same thing happen also. It shorted out my voltage regulator, when the altenator fell (truck got a litte warm too!). I replaced it with a grade 5 bolt. Not has strong, but it is less brittle. Hopefully, it will handle the vibrations better.
Rob
Hart_Rod is offline   Reply With Quote
Old 05-25-2006, 12:25 AM   #7
4x4Poet
Hallelujah!
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-25-2006, 08:41 AM   #8
Putter
More Cowbell....
Putter's Avatar
Hey....God is good!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-25-2006, 09:12 AM   #9
Orange
Licensed to Thrill!
Orange's Avatar
Originally Posted by Putter
Hey....God is good!
Couldn't agree more.
Maybe He was just checking to see if you'd give Him the praise after all the junk.
Don't you love it though when He lets something like THAT go right.
HALLELUJAH!!!
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-25-2006, 09:47 AM   #10
Gray Ghost
Gray Ghost's Avatar
Very nice!! Good lookin' motor as well....you have been blessed for sure on that repair!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 05-25-2006, 09:51 AM   #11
trailzen
Every once in a while when we are realy down he reaches over to pick us up.God bless everyone!
trailzen is offline   Reply With Quote
Old 05-25-2006, 12:21 PM   #12
BET68
Great To Hear Thanks Given To God In This Day And Time! Thanks For Your Post.
NAMASTE
B&E
1971 LONGHORN C-30
1969 LONGHORN C-20
1968 DUALLY
1970 STEP SIDE PROJECT
1972 CST C-20
1980 M-80 MALIBU FOR SALE
1974 NOVA FOR SALE:
BET68 is offline   Reply With Quote
Old 05-25-2006, 12:35 PM   #13
TugOwar
Very cool thread!
Kudos for giving credit where its due. For His Glory!
TugOwar is offline   Reply With Quote
Old 05-25-2006, 12:58 PM   #14
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Thumbs up Re: thank you Jesus, thank you lord
By Him therefore let us offer the sacrifice of praise to God continually, that is, the fruit of our lips giving thanks to his name. Heb 13:15
Way to go rage'nrat638.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
