Old 10-08-2002, 12:01 AM   #1
GMC 3
78 front crossmember swap?
I know this has been on here before, but just making sure before I do it. I have a 78 parts truck. I can unbolt front crossmember with everything still attached and roll it right under my 69 frame, right?
thanks
GMC 3 is offline   Reply With Quote
Old 10-08-2002, 01:21 AM   #2
crazy longhorn
Fabricate till you "puke"
Yes, that will work. altho i havent done that swap, i understand that there a couple bolt holes that need to be "egged out". im sure somebody has all the info. Good luck.....crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-08-2002, 06:06 PM   #3
jiggs
poker face
I just did that mod a little while ago. Yes it works, but you have to oblong two holes and drill two new ones. These holes are located on the vertical part of the frame ( where the upper control arm mounts.) Also you have to use the "69 motor mounts. The '78 mounts are too tall. The newer style frame is a taller unit. This in no way affects the suspension swap. Even the power steering and idler arm bolt right up from the '78. Good luck.
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month.
jiggs is offline   Reply With Quote
