Old 10-08-2002, 02:46 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Rearend Parts and Posi...where & what to buy
My next big step is to buy a 3.73 posi and all new bearings seals etc for my 12 bolt.
Problem is when I go to web sites and look at these things it seems the posi will be anywhere from 350 to 450 bucks. What is the difference in them?
Second, can't I buy a kit that gives me all the bearings, seals, gaskets, etc that I need?
I got a price of $60 to have it set up by a guy that does this for a living.....I thought that was cheap, but he said he didn't get a break on parts and I would be better off to buy the parts and bring them to him.
What should I have to pay to get a posi and all new seals? I will re-use my old ring and pinion.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-08-2002, 05:47 PM   #2
COBALT
COBALT's Avatar
I don't know if you've called these guys but they're kick-a$$ for info.
Randy's Ring & Pinion
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-08-2002, 05:58 PM   #3
1971Stepside
Almost Satisfied
Thanks Cobalt. I called them and you are correct, they are great. Great prices too.
Entire rebuild kit to include all gaskets, bearings, crush ring, etc for 112.00
Eaton 3.73 Posi: 339.00
Chrome Diff Cover: 19.00
Now all I need is the wife's checkbook!!
Old 10-08-2002, 06:17 PM   #4
Mike C
Mike C's Avatar
Cobalt has definitely steered you in the right direction with Randys. I would forgo the chrome cover and get stainless ARP bolts and re-paint your OEM cover. They are MUCH less leak prone and the chrome jobs rust after a year or two. (I have one on the JImmy, but only because of catastrophic failure...) $60 is a smokin' deal on an R&P setup. I've rebilt probably 30 diffs now and it's at least 4 hours to do it right.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-09-2002, 07:10 AM   #5
JimKshortstep4x4
Smile
Stepside,
Have you looked at Tom's differentials?
Eaton posi $280
Installation kit $100
www.tomsdifferentials.com/tomp.htm
Jim
Old 10-09-2002, 07:30 AM   #6
mikep
Used to have a truck
mikep's Avatar
$60 is a great deal on ring and pinion set up but thats not what you are getting. Sounds to me from your post that you are just installing a carrier and resealing your rear end. I know used carriers go for about $150 around here even if you pay too much and new clutches, bearings and seals will set you back about $120. Installing the carrier in your rear end isnt diffficult. You are not setting pinion depth in that case which is the most "difficult" part of setting upoa a rear end . You are only adjusting the gear mesh IF you even have to do that. White grease and a shim pack is all you need and you probably wont even use the shims. I know $60 isnt much and if that gives you peace of mind then great but personally I'd rather do it myself even If I had never done something like it before . That way you save a few bucks and learn a new skill. You have plenty of instructors who will teach you how for FREE right here.
No truck :-(
mikep is offline   Reply With Quote
Old 10-09-2002, 08:03 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Mikep,
I am looking into doing the exact same thing as 71 is doing. My shop told me it would cost $150 plus I would need new carrier bearings. Tom's Diffs quoted me at $280 for the posi plus $32 for the bearings and races and another $25 for shims. They said it was fairly easy. I have never done this. It sounds like you know how to do this. How do I go about this project as far as removing my old one first? Do I have to pull my axles?. Do I need any special tolls?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-09-2002, 08:33 AM   #8
Jeff M.
Jeff M.'s Avatar
I put the Eaton posi carrier in my truck. No special tools were needed. When I put the bearings on the carrier, I put the carrier in the freezer and the bearings in the oven and they tapped on without any problems. The stock shims worked perfectly, the gears set up without any problems. The rear end works great. Easy swap and the 'fun factor' has greatly increased!
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 10-09-2002, 08:53 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Does anybody know of a website with photos showing how this is done?. Jeff M how much of a noticeable difference did the posi make on your truck?
Jim
Old 10-09-2002, 09:19 AM   #10
1971Stepside
Almost Satisfied
The new issue of Truck Builder has a tech article on how to put a posi in a 12 bolt. I read it and am still confused. For $60 I will have the piece of mind that it is in there right. Thanks for the heads up on Toms. Sounds like the same stuff for less money. I will give them a call.
I hadn't heard the chrome covers leaked. I am not worried about rust as my truck should never see a day of rain unless the garage door is open!
Old 10-09-2002, 09:43 PM   #11
mikep
mikep's Avatar
Ive never had a chrome cover leak . Use a 1/8 bead of red RTV and let it set up completely on each side of the gasket before installing it. I do that to all gasket s and I dont have leaks on anything.
To install the new differential all you have to do is
A few notes first. You are not changing pinion depth so the majority of the set up blues are not there. Adjusting gear mesh is all that necesarry here. Setting pinion depth when changing ring and pinion is not difficult either but I wont cover that right not to avoid confusion. You need some specialized tools to do that . To change carriers you do not need any specialized tools other than common hand tools. Idid this same procedure over the weekend and it took me about three hours total until I was driving it. The first time I did it was when i was 15 with no outside instruction other than a poorly written manual so its not that difficult for the beginner.
1. On Full floating or semi floating axles pull the axles out a foot or so. On C clip axles you need to pull the cover first and remove the differential cross shaft .
2. Take off the cover
3. remove the carrier bolts
4. pull the carrier. sometimes theyre a little tight especially on dana 60's . You make need to turn the driveshaft to get the carrier to walk its way out.
5. remove the ring gear from the old carrier. might need to heat the ring gear with a propane torch to expand it a bit so it slides off the carrier. Dont hit it with anything harder than a lead hammer. Install the ring gear on the new carrier. toque bolts to spec. Typically 110 lbs or so.
6. Install the new carrier in the differential housing . Sometimes its pretty tight especially if you are using new carrier bearings.
7. torque the carrier bearing caps in place . check your chiltons for torque specs. 90-100 depending on the rear end.
8. turn the carrier over with the driveshaft yoke. If everything turns OK and it should if you are using the right carrier.
9. smear some white lithium grease on the teeth of the ring gear
10. install the axles with a few bolts if full floating. If c clip type then just slide them in for now
11 . pull you E brake a bit to give some drag on the brakes
12. turn the driveshaft over by hand or with a breaker bar
13. check the pattern the pinion leaves in the grease. If its right in the middle of the gear tooth you are good to go. 90% + of the time it will be as you have not changed the pinion depth and most modern rear ends are pretty standardized for dimensions. If the pattern is low on the tooth you'll need to insert a carrier shim on the left side as you look at it from the rear between the bearing race and the housing . .005 is a good place to start. Most good auto parts stores will sell you a rear end set up pack that includes carrier bearing shims. Randy's ring and pinion too as well as several sellers o ebay .
Once you get it in the middle of the gear face then wrap it up . Your done. Use friction modifier lube with your gear oil if its a clutch type posi.
No truck :-(
Old 10-09-2002, 10:45 PM   #12
Jeff M.
Jeff M.'s Avatar
70c10, in normal driving not much difference. But lay into it and I get the torque fishtail while the tires are spinning. Also, watch out on corners and water cause it will get away from ya quick. At the track I was able to knock off 3/4 of a second. This is with a 3.08 ratio. I'm thinkin of buying a set of gears and mount the slicks from the Chevelle and give it a try next season. Fun fun fun.........
