Old 05-31-2006, 10:26 AM   #1
bg67lwb
Water pump rotation
When was the change from multiple belts to serpentine? Does the water pump rotation change?
bg67lwb is offline   Reply With Quote
Old 05-31-2006, 10:36 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Re: Water pump rotation
For the trucks it was 1988 not sure about the burbs and blazers and yes if it is a single belt system the H2O pump will be a reverse rotation pump.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-31-2006, 11:00 AM   #3
bg67lwb
What happens if a water pump is run in reverse?
Old 05-31-2006, 11:06 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
It rewinds itself!
I would guess that you are asking if a water pump is put onto the wrong setup in error. (I.E. a standard rotation pump on a serepentine belt setup) The water flow through the block is the same on a reverse rotation setup as a standard motor, however the inside of the pump allows for the change in rotation, in it's design of the impeller. If you run a pump backwards the motor should exibit an overheating condition and the water flow will be really low.
