Old 06-01-2006, 07:31 AM   #1
gfcsteve
disc brake conversion
hi all, i searched the forum but didn't find the answer for this. i have a parts truck (1972 5-lug) that has disc brakes and want to put them on my 1969 truck, can i just replace the spindles or do i have to replace the a-arms too. i have already removed the whole assembly from the parts truck(unbolted crossmember and rolled the whole thing out from under the parts truck). it would be easeir to just replace the spindles i think. any comments?
thanks steve
gfcsteve is offline   Reply With Quote
Old 06-01-2006, 10:49 AM   #2
Aarons72s
Re: disc brake conversion
Youir existing a-arms are fine. You will have to install the 72 upper and lower ball joints. You will also need the center link and tie rods from the 72. Youir 69 center link and tie rods will not work. Hope this helps. Good luck.
Aarons72s is offline   Reply With Quote
Old 06-01-2006, 10:51 AM   #3
Putter
More Cowbell....
Putter's Avatar
Heck, if you have the crossmember out of one already, just pull the crossmember out of the other one and swap the entire assembly. I believe you will only need to create one additional bolt hole on each side.
Someone that has done this will chime in and fill in my missing details, I am sure!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-01-2006, 11:08 AM   #4
68haywagon
I'm watching you!
I'm getting ready to do this. I am swapping the entire crossmember. The 67-70 a-arms are different then the 71-72. I don't know if it does make a difference or not, but I am not taking the chance.
I think you only have to drill holes for the 73 and up crossmembers. I am not at the point of putting mine in yet, but IIRC the 71-72 is a direct swap.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 06-01-2006, 11:27 AM   #5
stevess11
I believe the only diff. in the arms is the tabs for the brake hoses. I put disc brake spindles on my 69 with no problems. As stated before you will have to use 72 ball joints and steering parts.
stevess11 is offline   Reply With Quote
Old 06-01-2006, 11:24 PM   #6
gfcsteve
thanks guys, the only thing about putting the whole thing under the truck is that i will have to pull the engine. if i got to i will but i would like to keep it in just so i can start it and move it around.
steve
Old 06-02-2006, 12:37 AM   #7
boraxman
Keepin an eye out
boraxman's Avatar
Swap the whole thing out. I went the spindle route, major PITA. I think you can get away with lifting the motor with a cherry pick and not yanking the whole thing.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
