06-03-2006, 02:03 PM | #1 |
burb dropping
Does anyone know how much lower a burb will sit VS a pickup using the same rear springs on both//the burbs are heavier are so I figger they will sit lower than a pickup..Anyone have any ideas,, brian
06-03-2006, 04:16 PM | #2 |
Re: burb dropping
Get springs for a burb! If you use truck springs yes it will sit lower but your ride will be crap since the spring rates are quite a bit different. Your call but it sucks doing things twice!
Kevin LFD Inc. |
06-04-2006, 02:51 AM | #3 | |
http://gmcpauls.com/springs.htm I recently purchased a set of variable rate coils for the rear on my C10 burb, but I haven't installed them yet. They're essentially "cargo" springs with closer spacing between the coil wraps the closer it gets to the frame. Supposedly, the bottom, farther-spaced coil wraps will absorb big bumps and give a near factory ride, but the upper, closer-wound coil wraps will prevent bottoming out and help support heavy loads to a point. I don't know what will happen to the ride height. I suppose one could install 3/4 ton springs on a 1/2 ton burb to support the burb's weight, but I don't know what that would do to the ride height either. I'm also not sure if that would be better than variable rate "cargo" coils.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-04-2006, 08:04 AM | #4 |
Re: burb dropping
I have never seen any burb springs either-I know they weigh at least about 500lbs more than a pickup so they should ride lower. I have a pair of new 3" drop rear springs on my pickup & thought of using them on the burb. I was just wondering how low to expect it to sit,,brian
06-04-2006, 11:02 AM | #5 |
Old School, New Style
Re: burb dropping
I bought my springs from Brothers (not installed yet) and they are specificly for the burb. I'm not sure that it was listed in there catalog but I asked them over the phone. When I recieved them they were marked for a burb and carried a different catalog number than the truck springs.
I think the best course of action is to call the co. you plan on purchasing from and have this conversation with them. Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
06-04-2006, 12:48 PM | #6 |
Re: burb dropping
wow,long roof I had no idea anyone specified burb springs,,guess I may try some new ones from Brother's also,,new stock springs I put in picked it up about 1 1/2" looks like a 4wd now,,brian
06-04-2006, 01:48 PM | #7 |
BlahBlahBlah
Re: burb dropping
wonder how much it would drop if you put in a used set of truck springs.
06-04-2006, 07:46 PM | #8 |
Re: burb dropping
Well, Brothers' website is no help. Like GMCPauls, Brothers lists three rear coil springs for 67-72s: Standard, Heavy Duty, and Variable Rate:
http://brothersonlinestore.com/products.asp?dept=687 No mention of burbs on any of the three links and, to make matters worse, Brothers used the same photo for all three springs types. Different part numbers, though. Long Roof, can you match the part # you received to one of the three springs listed & linked on that link above?
06-05-2006, 05:02 PM | #9 |
Re: burb dropping
On the box is a Catalog #LCSS36R-4 and theres another number on the box below it that reads 'RCS603-4H.D.'
Also says '1960-72 Chevy C-10 Heavy Duty Rear 4" Lowered Coil Springs' The description says 'Lowered Coil Springs, Rear, 4", Suburban I bought the suspension 'Stage 3' kit on sale for $600. I asked them for a suburban kit over the phone. They have a project 71 suburban so they should know what there doing. Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 06-05-2006 at 07:29 PM. |
