06-04-2006, 10:17 PM | #1 |
Alternator Bracket Too Short
In between periods of being frusterated by the 700r4 install I'm trying to straighten out a few others things that need attending to.
One is the alternator bracket. My 68 has the factory bracket installed, as pictured below (thanks Luv). My problem is with the adjustment part of it. I forget the belt lengths at the moment but one length is too short and the alt hits the valve cover. 1/2" longer and the bracket is too short to tighten the belt. I picked up an after market bracket (the arm part) at autozone that was longer but it had the wrong curvature. I maybe could have ground some off the lower edge of it and made it work but opted to return it, get my 12 bucks back and look for a better option. Since this is factory bracketry I know some one else has run into this before. What did you do to correct it? |
06-04-2006, 10:35 PM | #2 |
The LuvShack Garage
Re: Alternator Bracket Too Short
YOU STOLE MY PIC The one attached is the factory one, the other
is one I got as part of a parts deal, if it is curved the same, will have to look at it tomorrow, I can give you the dimensions so you can match up.
06-04-2006, 10:50 PM | #3 |
06-04-2006, 11:16 PM | #4 |
i had this problem, i had to extend the bracket about 3 inches with some creative angle iron and bolting it to the manifold. this is a chrome version with the same angles and lengths as the original.
i don't know if these pics show it, but it's the best i got since my truck's in paint |
06-05-2006, 06:51 AM | #5 |
'72 trucks have a longer curved adjustment arm that can be used with your brackets to solve your problem.
Tim |
06-05-2006, 07:03 AM | #6 |
my friend 67 was like that i used the shorter belt and once in the pully was able to adjust it
06-05-2006, 12:12 PM | #7 |
"Trucks with Class"
You have to run the later (72?) arm when you use tall valve covers. I save them just for that reason...so go to the longer arm or cut and weld and grind in an extension piece.
Yes, you will have to run a longer belt. |
06-05-2006, 01:39 PM | #8 |
Ok, so I need to dig up a 72 (Or later?) arm and all is well. 72 is gonna be hard to find.
Oddly these aren't tall valve covers. They're old Erson chrome covers. Were on the truck when I got it. Never been cared for so they're more rust that chrome, but not beat up. Wish I knew a way to strip the chrome off so I could paint them. But thats beside the point. Thanks for the very good info guys, looks like a boneyard trip is in order. |
06-05-2006, 01:41 PM | #9 |
my 72 arm is the same as the chrome one i have, it's still short. i had to extend it 3 inches with angle iron as said earlier.
06-05-2006, 02:03 PM | #10 |
So I suppose another alternative would be to move the alt to the passenger side? I'd need the brackets of off... 73-87?
06-05-2006, 02:24 PM | #11 |
well, you're aiming at a short water pump style. the later trucks use a long water pump style.
06-05-2006, 03:38 PM | #12 |
The LuvShack Garage
IIRC Passenger side mounted alts are long h20 pump only, but I
could be wrong, let me know if you can't find one, it's a extra
