06-11-2006, 09:09 PM | #1 |
I need 3 drive shaft measurements, please?
All are for SWB with small block.
1) Long tail TH350 2) Short tail TH350 3) TH400 Also, what are the measurements for the actual transmissions? I know I have a TH350, however, I don't know if it is a long or short tail.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 06-11-2006 at 10:43 PM. Reason: Added motor info. |
06-11-2006, 09:34 PM | #2 |
71 GMC 454/TH400
Re: I need 3 drive shaft measurements, please?
My big block and turbo 400 drive shaft measures 68" center joint to center joint. The short shaft 350 tail shafy should be around 6" I think. I can get some exacts on that tomarrow.
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
06-11-2006, 09:54 PM | #3 |
its all about the +6 inches
a small block with a short shaft TH350 in a SWB truck would be 4 foot 10 inches.
06-12-2006, 07:17 PM | #4 |
71 GMC 454/TH400
"The bigger you are the harder you fall, the farther you walk the longer you crawl." Last edited by farmtruckIII; 06-12-2006 at 07:18 PM. |
06-13-2006, 04:30 PM | #5 |
I measured my two piece on my 69 - I have a 350 eng with TH-350 tranny that has a 6 inch tail. The front shaft was 25 inches from center to center and the rear is 35 center to center.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
06-13-2006, 04:42 PM | #6 |
Junior Member
A TH400 is around 29" long.
Clif '68 C/10 LWB, 327, TH400, 12 bolt |
