70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Is it worth it ?
I have a 700R4 that I can put in my truck. My truck has a 396 and TH400 right now. I love the way my truck runs but would like better mileage and I know the 700R4 will increase my mileage especially on the highway.
Its going to cost about 800.00 to put the 700 in my truck and I was ready to do it then started to second guess myself.. I'm looking for opinions and pros and cons of the TH400 versus the 700R4 !!!!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Apr 2005
Re: Is it worth it ?
It's win-win if the tranny is built to handle the bigblock. You get a Lower 1st gear (so quicker off the line) and then you get OD for highway cruizing. Just make sure it is built to handle the torque of the BBC and the TV cable is adujsted correctly.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
laying low
![]() Join Date: Mar 2001
You must also consider the rear end gear ratio. OD with a high geared rear can hurt mileage. Use something like Richmond gear calculator to see if the final drive ratio will yield better possible mileage. www.richmondgear.com
its all about the +6 inches
Boog beat me to it, and many simply don't believe this, but yes, an overdrive will not always help MPG, and can actually hurt it.
#5 | |
he means the 700 isn't a very strong unit to begin with, and a big block is a torquey motor.
The 700R4 is a great tranny when built right! I had one built by a local shop near Sacramento A.T.O. and it cost me $2800 and is guarentied for 700HP but only out of a small block!!!! Big blocks just have to much torque through out the power band of a 700. You need to go to a 4L80 if you dont want to be left on the side of the road during those traffic runs! Just my $.02
![]() Kevin LFD Inc. |
naaa, 4L80E is way too expensive to set up. A TH400 with a gear vendors would be better, and cheaper.
Heck, if your TH400 is a strong well maintianed unit, you could go a gear vendors for about 1200 or so... not a whole lot more than the 700 numbers listed here, and WAY stronger. You'll NEVER break a gear vendors, plus, you'll have a 6 speed. |
member #16
![]() Join Date: Dec 1999
If you want a little sticker shock look at the prices for gear vendor. They have gone up a tad. Look at price code D
http://www.gearvendors.com/prices.html
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 06-10-2006 at 07:53 PM. |
![]() Join Date: Aug 2004
You can find 'em on fleabay for about a grand used.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
that is true, if you are looking for a 2wd setup, and have some fabrication skills, you can always find some aux. overdirve setups that would bolt to the rear of your TH400.....personally I would stick with your TH400 and throw a couple hundred at getting an aux. overdrive.....the cost of beefing up your stock 700R4 plus installation......you could buy a couple cases of beer and an aux. overdrive.....and possibly trick some local members into helping you with the install :smile:
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
I have a guy her in Calgary that is building my 700 for my 502 Ramjet the will handle all of the 585ft/lbs plus more. He will stand behind his work, as he builds many tranny's for local racers.
If you need his number, PM me.
67- 72 Parts collecter |
Would I see better mileage on a diesel 2wd (2.76 or 3.08)with a 700r4(lock up converter) or a turbo 350 or 400?Also would a 6 speed manual from a latemodel f body bolt up and hold up to a N/A6.5? would a stock diesel flywheel work which clutch would i use f body or truck?
Thanks Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
with gearing that low, you'd probably be better off without the OD.
#15 |
What gearing should I run?.......with 2.76s it would be running 150mph in overdrive at 3500rpm
![]() Shane
#16 |
![]() Join Date: Nov 2004
If you want to run an OD tranny (IMO) you should have a rearend with at least a gear in the 3.40's and if you do any towing or hauling a 3.73 would be best. A lot of new trucks with OD run 3.73's. My z71 has a 3.73 locking rear
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 06-12-2006 at 11:38 AM. |
#17 |
Thanks everyone for the thoughts. ideas and opinions on my transmission dilema. I think for now I'll take my TH400 get it checked out and serviced and use it for the time being. I'll tuck the 700 away in a corner of the garage (cause they dont deteriorate from sitting) and spend the 800.00 I was gonna spend on the trans swap on my lowered suspension..
