Old 10-09-2002, 11:16 PM   #1
Pumkin Truck
Thats just prime!
Pumkin Truck's Avatar
How would I get better 6 cyl gas mileage?
K, here is the deal, I got a better job offer that pays hell of a lot better than my current job, to be exact, it is thirty miles away. My six is all stock from the ugly air cleaner to the oil pan, My question is, should I buy a 4 spd tranny to replace my 3 spd chicken leg since it would be all highway driving? I am really debating this. thanks for all the help. Oh yeah would it be a direct bolt on with out modifying my drive shaft? thanks
*69 GMC short bed stepside with a wimpy six that can barely pull itself.
*99 Chevrolet Camaro Z-28
1 Bad 5.7ltr LS1
Pumkin Truck is offline   Reply With Quote
Old 10-09-2002, 11:20 PM   #2
whateva
The final drive of a 3 speed and a 4speed are the same. On the highway it will make no difference.
whateva is offline   Reply With Quote
Old 10-09-2002, 11:34 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Give her a real good tune up, install HEI, open air filter, (and rejet if needed) play with the timing, get taller rear tires, and keep your foot out of it.
Old 10-10-2002, 09:55 AM   #4
jku72
Buy a used 3.07 rear gear and swap it in. They are cheapo, and not too tough to install, and way cheaper than an overdrive trans. That one step will net more mileage than any other trick.
As long as it is a half ton, there is plenty of gears available, since the rear gears were bolt inable from early 60's to late 70's. 10 or 12 bolt axle gears and carriers can be had CHEAP in those 3.07 or 2.76 ratios. If you were rowing a 4 gear, I would recommend the 2.76(2.67?) because of the granny low, but with the three on the tree/six combo I would only go to 3.07:1.
I expect if the engine runs decent, 20+ mpg with the 6. Heck, my suburban with a 350 4 speed get 19mpg with a 3.07. You could beat that with 2 less cylinders.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 10-10-2002, 10:40 PM   #5
Pumkin Truck
Thats just prime!
Hmm.. thanks everyone, If i remember my truck only got like 11 miles to the gallon at TDC. When I rebuilt the motor, I took apart the intake/exhaust manifolds to paint the intake, I forgot to realign them before i put them back on (stupid! STUPID!) and now I have to take them back off because excess air is getting in with the gas/air combo. about five years ago my dad did the same thing, but he aligned them as best he could, then took it to the machine shop where they resessed it making it as flat as possible. I am thinking about doing that also, Would that mess with my gas milage?
1 Bad 5.7ltr LS1
Old 10-10-2002, 11:15 PM   #6
Alaskan
Truck'n the alcan
Alaskan's Avatar
All good advice, also get a vacuum gauge and test and tune. Tires play a big role in fuel economy, cheap ones tend to have alot of sidewall deflection. I would use a LT rated tire and stay away from the P-Metric. Proper wheel alignment helps and synthetic oils.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-11-2002, 01:10 PM   #7
Brad
Out of the carpool lane.
Brad's Avatar
Post
After having done the 3.07 with my I6 and 3 spd, I wouldn't do it again. In fact I've got another 3.73 and am considering putting that back in. Eventually, I think a 3.42 or so will be exactly what I will do. I would like to put in a T-5, but $$$ prohibits me from doing so. If I could do that with the 3.42, that would be ideal. I really don't get any better gas mileage with the numerically lower gear. I think it's the amount of clutch and gas I have to use to get the truck going from a dead stop negates the highway mileage. Really, for me there wasn't much difference except now I'm very slow off the line. I can go up to 90mph though, which you don't want to do with 3.73!
Actually, I've secretly been considering the V8 conversion (shhhhh!) for down the road because of the cost of 6 performance parts and the fact that some V* guys are getting 20mph like jku is saying. I'm only getting 17mpg! Dang those V*'s!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-11-2002, 03:56 PM   #8
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
307 conversion
Brad, I have a 67 LWB with a 6 banger in it also. Mine is a good running fresh rebuilt 292. I was just wondering what condition you 250 is in. That would give me more of an idea about the performacen. Because I know the 3.07's would give me another 4 on the highway minium. I have the gears and am still in need to a posi carrier? I would be willing to buy someone's in good condition. Anyways email me what you think the outcome of the 307 would have with a fresh 292. I like the performace it has now, but need to go faster than 50 on highway. Right now im 55 at 2500 with about 30 inch tires.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 10-11-2002, 05:27 PM   #9
mikep
Used to have a truck
mikep's Avatar
How do you get 415 ft lbs of torque from a 292?
No truck :-(
mikep is offline   Reply With Quote
Old 10-12-2002, 04:10 AM   #10
Brad
Brad's Avatar
Hmmm, it might work for you. I just turned 100,000 miles on the 250. Also, I'm screwing with this Weber 32/36 trying to tune it for a 6. You probably have a little more horses and it might work for you.
Old 10-12-2002, 01:49 PM   #11
GMC71k20
get a header
GMC71k20 is offline   Reply With Quote
Old 10-15-2002, 08:04 PM   #12
Kas68c10
Kas68c10's Avatar
All good suggestions,pretty much what I did. I have 3.73 gears ,a t-5, HEI, headers,electric fan,weber carb with k &n filter, but too small a tire on my truck. Depends how much $ you want to spend. I only get 20 mpg, but then the engine is original, I have never even had the valve cover off it. A rebuild of a 292 is in the plan this winter.
The tune up, rear end gear swap, hei, open air filter are probably what I would do first. A compression test and vacuum test would be a good idea. The t 5 is nice, I rev 1800 @ 60 mph, 2000 @70. Probably off a bit because of the tires, but I love cruising in the truck and being able to have a conversation. Headers didnt seem to do much, but it sounds good. The electric fan I think helped power, not economy.
Hope that helped, and good luck
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 10-21-2002, 07:20 PM   #13
Brad
Brad's Avatar
Holy Cow! I got 19.5 mpg doing 65 for 3 hours. I also put more air in the tires too. I've got a tonneau on it also. That is the best mileage I've ever gotten in the truck.
