Old 04-26-2002, 09:43 PM   #1
cman
Red face broken bell housing
A freind of mine has a '69 C-10 with
a 454 and a power glide. It has broken the
bell housing on 3 transmissions. I havn't seen the truck, so I am basing my info on what he is telling me.
Is a 454 too much for a powerglide? The only thing I can think of would be the engine
is lifting up on accelleration and the bellhousing is hitting the cab causing it to break!
Thanks for any help!
70 C-10 Fleetside, short box.
92 1500 Fleetside, short box
95 Tahoe 4X4
cman is offline   Reply With Quote
Old 04-26-2002, 09:51 PM   #2
Benrs86
Benrs86's Avatar
Post
from what i have heard powerglides are strong. maybe something is out of alignment? good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 04-26-2002, 09:54 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
that is not a normal problem, that is drivetrain alignemnt problem
driveshaft being out of alignment(side to side) will cause that, the action of the shaft trying to straighten out and be in perfect alignment from output shaft of the p/g and to the pinion of the rear axle wil cause the tranny tail to be pulled to left or right, whichever is needed, to straighten out the driveshaft, and if motor mouns wont flex, then pop goes the bellhousing.
i owuld check out driveshaft alignment, especially if is not original or he is using non stock crossmember or has modified rear suspension
Randy- Lincoln, IL
r68c30@hotmail.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 26, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-27-2002, 04:52 AM   #4
GMCPaul
Post
Bad thrust bearing on crank.
GMCPaul
Online Catalog for-GMCPauls Truck Parts.com
67 LWB GMC SuperCustom Fleetside
67 LWB GMC Stepside
67 SWB GMC Stepside
67 SWB GMC Fleetside
67 SWB Chevy CST Fleetside
67 LWB Chevy CST Fleet
67 SWB Chevy Stepside
67 LWB Chevy Stepside
68 2wd Chevy 1/2 t. Panel
68 Chevy Panel 1/2Ton 4X4
68 LWB Chevy Fleet 4X4
69 SWB Chevy Stepside
71 GMC Suburban 402/400
72 LWB Chevy Camper Special
Nope not a typo 2-72 Camper Specials
and no they are NOT FOR SALE MINE MINE MINE and we accept ALL 67 Refugees Looking For More Never Enough!!!
GMCPaul is offline   Reply With Quote
Old 04-27-2002, 08:44 PM   #5
Mike C
Mike C's Avatar
Post
Powerglide case can take 1000hp if everything else is right. I think fast is on the right track with the drivline out of alignment. Truck may have been wrecked at one time. Time to start measureing. Also could be he is running a solid trans mount.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
