Old 10-10-2002, 01:18 PM   #1
Canada20
Question So what does a kerfaggled converter do?
OK I'm being a smart-ass but as usual I have a question from somebody else's question. What are the signs of a messed up torque converter? I'm going to be getting ahold of a truck on Sunday that apparently works alright except for the converter and I'd like to know for myself. Thanks
Greg
(BTW the guy I'm buying it from is trustworthy and has asked around some of his mechanic freinds to find out what's wrong with his truck.)
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 10-10-2002, 01:47 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
If it's totally shot, it'll just sit there and rev, no matter what gear it's in. It'll still have park, but no forward or reverse gear.
If it's on it's way out, it might vibrate ALOT at certain engine speeds.
-Jeff
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-11-2002, 12:40 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
HEY! THAT'S MY WORD!
heh heh heh...
Old 10-11-2002, 11:26 PM   #4
Canada20
Heh...sorry. Had to "borrow" it since it's a good one. You can have it back now, if you'd like....
Thanks for the replies BTW. I think the trouble the owner is having is that the engine pretty much won't run. It'll turn over but I guess the converter bogs it down? Does this sound possible? I'm being a little pre-mature in asking questions when I haven't even played with it myself but I thought I'd ask and see if this sounds like something typical...
Many thanks,
Greg
Old 10-11-2002, 11:52 PM   #5
Longhorn Man
Unbolt the 3 verter bolts and push it rearward, that will delete the tranny from the 'won't start' trouble.
Old 10-11-2002, 11:55 PM   #6
Canada20
WHOA! how easy is it to do that?
Greg
Old 10-12-2002, 12:04 AM   #7
Longhorn Man
Look at the flywheel, you'll see bolts holding on the verter. Just unbolt them. You'll have to bump the motor over to get to all of them, but you can do it in less than 5 min once you have your 9/16's socket and same size open/box wrench.
Old 10-12-2002, 12:08 AM   #8
Canada20
that doesn't sound bad at all. Hopefully the weather will improve in the next week and I can give this a shot, thanks. Are converters fairly easy to remove? Sorry for all the obviously new guy q's ut I've gotta start somewhere, right?
Thanks again,
Greg
Old 10-12-2002, 12:20 AM   #9
Longhorn Man
Pulling a vertr sounds easier then it really is.
Drop the drive shaft, unbolt tranny mount, unbolt tranny from engine, slide back and verter will pop out of tranny by pulling on it...same work as dropping tranny.
Sounds easy, but it is a b!tch in reality.
Old 10-12-2002, 12:56 AM   #10
Canada20
Thanks for all these fast replies. Obviously the next questions you guys are going to see from me are "how do I remove my trans" and the like. When I saw that Haynes wouldn't even put that in their manual I started to wonder what I'm getting myself into.
Thanks again,
Greg
Old 10-12-2002, 01:04 AM   #11
cableguy0
with the truck only up on jack stands i can have the tranny on the bench in under a half an hr. its a th350. it will take u a lot longer if the crossmember has never been removed b/c i think they were all riveted in from the factory
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-12-2002, 01:09 AM   #12
Longhorn Man
Actually, from what i understand, only the manual shift trucks were rivited in.
All 3 of mine were bolted, but they had all had the trannys pulled at one time or another.
