Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-22-2006, 06:23 PM   #1
chevyboy55
chevyboy55's Avatar
Speaker Locations
Where have people put speakers other than the kick panels or in the doors?
I am thinking of putting 6"x9"s in boxes in the rear corner of the cab where the gas tank was. Any pics?
chevyboy55 is offline   Reply With Quote
Old 06-22-2006, 07:35 PM   #2
ChevyDude
Re: Speaker Locations
I put Infinity Kappa 6x9's in the corners. Boxes are custom made fiberglass houses, then covered with a leather looking black vinyl.
ChevyDude is offline   Reply With Quote
Old 06-22-2006, 07:42 PM   #3
chevyboy55
chevyboy55's Avatar
Great minds think alike! That's just about what I'm thinking.
Old 06-22-2006, 08:33 PM   #4
ChevyDude
Here are the front components houses: Your feet don't really have a problem...as they straddle the speaks. They would have cause many more problems in the kick panel area. Best...They sound awesome!
Old 06-22-2006, 08:51 PM   #5
pumpkin
pumpkin's Avatar
There is a headliner kit that has 4 speakers in it. I think LMC sells them, about $200. with speakers.
pumpkin is offline   Reply With Quote
Old 06-22-2006, 09:05 PM   #6
wakeboarddrumma
wakeboarddrumma's Avatar
Pumpkin,
The speakers can only handle 10 watts though
I put mine under the seet, in metal frames.
wakeboarddrumma is offline   Reply With Quote
Old 06-22-2006, 09:41 PM   #7
Sheverlay
Sheverlay's Avatar
Unless your just looking to just get some basic tunes in your truck, putting speakers in the kick panels will give you the best sound out of any location in your vehicle. Putting full-range speakers under or behind your seat aims them towards the floor boards or back of the seat(away from your ears) and muffles the sound.
Assuming there is enough room and whatnot...if I were putting together a system, here's what I'd do:
5 1/4 or 6 1/2" (whichever will fit) components in the kick-panels
6x9's ( or largest that will fit) in upper rear corners for rear fill
8 or 10" sub(s) under or behind seat
Here's some universal Q-Forms kick-panel enclosures, if ya dont wanna build your own. Kinda pricey if you get em from Crutchfiled, but you should be able to find them cheaper if you shop around a bit.
http://www.crutchfield.com/S-69obkaP...search=q+forms
Sheverlay is offline   Reply With Quote
Old 06-22-2006, 11:06 PM   #8
70c10
67-72 Addict!
70c10's Avatar
This is another option
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-23-2006, 01:27 AM   #9
MisterMan
MisterMan's Avatar
wow, clean truck, what is the box composed of?? how is it attached, and dont say nail gun, hahaha
--den den
MisterMan is offline   Reply With Quote
Old 06-23-2006, 03:05 PM   #10
70c10
67-72 Addict!
70c10's Avatar
They are just A.B.S. plastic pods that are screwed in.
Jim
Old 06-23-2006, 07:38 PM   #11
farside847
farside847's Avatar
I put two infinity 6x9's under my seats, 300w max with VERY nice sound. I traded in my kickers for these bad boys and have never been happier.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-23-2006, 08:01 PM   #12
matthufham
i welded the corners shut. you can only fit a 5"X7" this way, if you angled the corner piece you might be able to fit a 6"X9"
matthufham is offline   Reply With Quote
Old 06-23-2006, 08:57 PM   #13
QKENUF4U
QKENUF4U's Avatar
set of 20$ box speakers from CHECKERS behind the seats in the corners and one 6.5 under the dash in the stock location and im gonna put speakers in the vent openings (already cut the 1/8" plywood and covered it in gray carpet) just have to get the 6.5" speakers and cut the holes. already sounds awesome with just the rear speakers. this truck has the best accoustics of any vehicle ive ever owned.
QKENUF4U is offline   Reply With Quote
Old 06-23-2006, 09:14 PM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
5 X 7 speakers
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-23-2006, 10:25 PM   #15
matthufham
hey mocown, good idea. those are the same speakers and setup in the corner i have
Old 06-24-2006, 12:02 PM   #16
Lippyp
English Chevy Owner
Lippyp's Avatar
I'm going with an 8" RE8 sub and an alpine mono amp under the seat and a second amp for the fronts. To start with they'll be the three way JBL 6x9's currently in the back end of the door panels but eventually I'll go for some decent components up front, probably in the doors.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-24-2006, 01:32 PM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Some of the vendors will have a speaker set that fits in the stock dash location.It is a double speaker,it hooks one side to each channel.I don't know the amp rating.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-25-2006, 12:03 AM   #18
hugger69SWBCST
I go some round little speakers under the seat rolling around. My kick panels are carpeted so got good excuse for not hacking holes on it!!! eventually I just put some boxes with 6x9 under the seal and leave the little round ones there to!!!
I like the setup of "The inglish roastbeef" :=)
hugger69SWBCST is offline   Reply With Quote
