Old 06-22-2006, 09:08 PM   #1
incoma
incoma's Avatar
ECE is closed and I need a quick intall tip - shock kit
I've got some odd looking bolts in my shock relocator package that I'm not sure what to do with. They have a large pan head on one side, a non-threaded shank and then a threaded end and came with 3/8" thick spacers and nuts.
What do I use these for? The shank on the stud is too big to fit through the lower shock mounts...???
incoma is offline   Reply With Quote
Old 06-22-2006, 10:17 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: ECE is closed and I need a quick intall tip - shock kit
Thoose are the lower shock bolts
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-22-2006, 10:25 PM   #3
Hart_Rod
Hart_Rod's Avatar
If you didn't buy ECE's shock kit, I don't believe you need them.
Rob
Hart_Rod is offline   Reply With Quote
Old 06-22-2006, 10:40 PM   #4
incoma
incoma's Avatar
I did buy their shock kit. Do these studs install from the inside of the truck out? Or should I drill the bracket out so I can install them from the outside of the truck in?
Old 06-22-2006, 10:43 PM   #5
Hart_Rod
Hart_Rod's Avatar
Do the shocks have a metal spacer in them? If so, take it out and see if the bolt fits.
R
Old 06-22-2006, 10:46 PM   #6
incoma
incoma's Avatar
No spacer. These are the KYB shocks and they do fit over the stud shafts. If I try to install the stud from the outside (wheel side) of the truck, The hole in the bracket will need to be drilled out. If I install from the center of the truck, I can bolt this unit right up to the bracket without modification, but it doesn't look right.
Old 06-22-2006, 10:54 PM   #7
Hart_Rod
Hart_Rod's Avatar
I see what you mean now. I don't think that would be a problem though. Is hole just big enoug for the threads to go into? If you don't like that drill the bracket out, it won't hurt anything. Check this article out:
http://www.earlyclassic.com/tech.asp...0Big%20Ship2-3
rob
Old 06-22-2006, 11:00 PM   #8
incoma
incoma's Avatar
I read that article and wish you could enlarge the pictures, b/c the stud they have mounted in that lower bracket isn't the same one that I have in my kit. It just seems to me that the stud should mount to the bracket, and then you mount the shock to it. If you just bolt the shock to the bracket it won't be as strong of a connection.
Old 06-22-2006, 11:50 PM   #9
jsbgump
Gone Fishing
jsbgump's Avatar
[QUOTE If I install from the center of the truck, I can bolt this unit right up to the bracket without modification, but it doesn't look right.[/QUOTE]
This is how i did mine a month ago with the ece kit and they have worked great
Build Thread
Old 06-22-2006, 11:51 PM   #10
jsbgump
Gone Fishing
jsbgump's Avatar
I can get you some pics tomorrow
Build Thread
Old 06-23-2006, 07:52 AM   #11
Joe67
67 is sold
I installed that kit with the ECE KYB shocks. My bolts are mounted outside to inside. Makes the shock change a little easier down the road.
I'd wait until you can contact ECE directly before you do any drilling
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-23-2006, 09:07 AM   #12
incoma
incoma's Avatar
joe67 - did you use normal bolts or the special studs that came with the package?
Old 06-23-2006, 10:48 AM   #13
jsbgump
Gone Fishing
jsbgump's Avatar
Here's a pic
Build Thread
Old 06-23-2006, 11:27 AM   #14
incoma
incoma's Avatar
Well, that's what I'll do then. I guess that extra spacer that they provide squares everything up pretty well.
Old 06-23-2006, 12:17 PM   #15
Joe67
67 is sold
I used what came with the kit.
Give them a call, their customer service is 2nd to none
Here are pics of my setup:
http://67-72chevytrucks.com/vboard/s...d.php?t=120971
Old 06-23-2006, 04:56 PM   #16
cornutz
All Praise RANDY!!
cornutz's Avatar
Do it the way you have it, dont drill a thing!!! They are designed like that for the sole purpose of making it ride nice...
cornutz is offline   Reply With Quote
Old 06-23-2006, 11:35 PM   #17
incoma
incoma's Avatar
I called an apparently they have 2 different sets of studs/bolts that they provide with the kit. They've experimented with different setups to see what they want to sell. My kit looks like jsbgump's and is supposed to be bolted just as he did.
The guy on the line was going to send me the studs that they normally ship with these kits now but since we figured out what I had, I just used those. I'd prefer to have the studs - because I'm anal - but the bolts will work just fine.
Its amazing how big of an improvement the shock relocator kit made - even just driving around the neighborhood.
Old 06-24-2006, 12:16 AM   #18
jsbgump
Gone Fishing
jsbgump's Avatar
Yup it is a really nice ride
Build Thread
