06-27-2006, 11:09 PM | #1 |
Valve Ground Quest
I have the ground for the solenoids grounded to the frame and they wouldnt open when I hooked up the power to the switch box.I also had a problem with the air compressor starting.I bought my kit from suicidedoors.The 8 valeve kit.
06-28-2006, 12:22 AM | #2 |
Re: Valve Ground Quest
Do you have a good ground at the chassis? Do you have a ground strap from the motor to the chassis or one from the battery to the chassis? Try running some jumper wires from the battery to the 12V input and the ground input at the valves to test them. Do you have 12V at the battery?
06-28-2006, 12:25 AM | #3 |
Thanks for the advice
06-28-2006, 01:07 AM | #4 |
Epoxy Primer Friendly
Use one of these to hookup your valves and ground. Much cleaner.
06-28-2006, 09:07 AM | #5 |
'cept, don't mount it on a peice of wood
06-28-2006, 02:39 PM | #6 |
Not mine lol Found this pic online !
06-30-2006, 11:08 PM | #7 |
I have 12v on the battery
I tried my valves with the jumper straight to the battery no good I have a good ground My relay has one wire that isnt in my diagram? |
06-30-2006, 11:21 PM | #8 |
Is it the middle terminal in the relay? Often times the middle wire on a 5-wire relay goes unused.
07-01-2006, 11:39 PM | #9 |
Do you think I need to have all three prongs on my valves hooked up?
07-02-2006, 01:14 AM | #10 |
Hollister Road Co.
Here is a relay diagram.
07-02-2006, 02:27 AM | #11 | |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
