C10 Club Tennessee
Anybody rebuilt there PS Gear Box?
Has anyone done this or can help with it? I bought a gear box at the junkyard the other day and I got a 3/4 ton one, so it's pretty much worthless to me. I figured instead of going and getting another one that I might rebuild the one I have. It leaks at the top of the gear box where the steering shaft goes in.
I know that the parts stores sell two different kits for them. Don't know which one I'd need for to fix my particular problem. One is the complete rebuild kit, another is the seal kit, and the last one is the Input seal Kit.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 06-30-2006 at 05:33 PM. |
Re: Anybody rebuilt there PS Gear Box?
A seal kit, possibly just that seal. I have rebuilt one or two, just pay attention to how it comes apart (mostly the number of turn on the nut from the steering shaft, too tight and it won't turn too good!)
I would change just the seal needed. I've done the whole box before.. Took me 2 kits because I ruined one of the teflon rings going together. Keeping track of all the balls is a bugger too. Next time I'll just buy a rebuilt unit if the whole thing needs doing.
Doing just the input or output seals though, isnt too bad to do.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I've rebuilt mine...probably would not try it again. I would go reman. If you decide to do it, get the master kit and like chevymad said, be very careful with those teflon seals.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
C10 Club Tennessee
So would it be this seal that needs to be replaced?
http://www.oreillyauto.com/EW3/ByKey...ring%20Gear%20
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Jun 2005
The parts book lists the steering gears as the same for 10-30 series, so the 3/4 ton gear will work? After you remove the threaded plug and pitman shaft, take a piece of 3/8 fuel line or copper pipe and as you turn the flange the lower housing will move down and out, continue to push the hose into the center of the housing. Reverse the procedure to assemble. As long as you don't remove the hose or pipe the balls will stay in place.
Chevrolet and GMC published a Service Manual and an Overhaul Manual. Find and Buy the Overhaul Manual, its the best money you will spend, if you are doing the work yourself. |
C10 Club Tennessee
The shaft is different on the one that I got from the junkyard. It came from a 79 Blazer. That's why I figured it was a 3/4 ton.
The LuvShack Garage
Just buy ya a AGR like GQ
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
C10 Club Tennessee
I'm not rolling in the $$$$ like GQ
yellow69 PM sent
C10 Club Tennessee
Not a bad nut after all..
I went the parts store remanufactured route. Cost just over $200. It was tight at first, but after six months it started getting sloppy again. I question the quality of the remanufactured boxes.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
C10 Club Tennessee
I guess my question that I need to ask is which seal is it that I need to replace if it is leaking at the top of the gear box where the shaft connects?
Is it that Input Seal?
C10 Club Tennessee
ttt
#15 |
If you want to replace the seals only, the ones where the rag joint attaches to the steering shaft, I believe you will have to buy the complete kit. When you take the big nut off be sure to count the number of turns. You might want to scribe a line on the nut and the housing just to make sure you put it back in the same place. I replaced one recently, but I cannot remember if I purchased the complete kit or a shaft seal kit. There are 2 lip-type seals in that nut. assy. and an o-ring or two. Good luck! Tell us how it turned out.
Bob
#16 |
On the used gear, my wrecking yard told me the the 10-30 2wd truck gear was the same until 76.
#17 |
2WD and 4WD use different boxes.
#18 | |
Good thread, Billy
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
#19 |
I think I bought mine from NAPA for $170. or was it $270. I thought it was worth the $ to not screw up my original box. I wish I could have gotten a different turn ratio particularly with my 8" rims.
