Hunting is Life
motor oil in brake booster
Well I finaly found a truck thats worth working on, when I popped the lid off the brake booster it was full of oil. Could this hurt any of my brake parts? NO WONDER MY BRAKES DIDN'T WORK.
![]() Pat ![]() |
I am going to take a WILD GUESS and say someone connected the vacuum brake hose into the valve cover. It should be connected to a vacuum source like the rear of the intake manifold or the bottom of the carburetor. Just an uneducated wild guess.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
brake fluid probabally//new master and booster
![]() ![]() Join Date: Jan 2005
Is the oil in your master cylinder reservoir, or is it inside the vacuum booster itself?
brake fluid is polyglycol based petroleum will make all the seals in the system swell....new master cylinder calipers wheel cylinders anything with rubber seals....and you will need to completely flush the lines with brake clean and compressed air....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
bump...and the answer is...
#7 | |
Msgt USAF Ret
oil in brakes
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Hunting is Life
Re: motor oil in brake booster
stupid me the oil was in the master cylinder reservoir :rolleyes
pat |
I have the same problem, but it is the rear seal in the back of the master cyl that is leaking. Some fluid looks like it went into the vacuum booster. We'll see what happens after I change the MC.
1997 GMC Sierra Ext 1965 Mustang |
