Old 07-10-2006, 06:01 AM   #1
k-20
strange noise
ive had a strange noise in the truck for a while now,it seems to be coming from front of gear box?the noise isnt allways there,after driving for about 3/4-1 hour a bearing noise?? appears but when you push the clutch in the noise decreases to almost 0.a friend thinks it is the spigot bush,but i didnt want to pull gear box and transfer out just to lube the bush,only to find that its not the spigot!any sugestions would be greatly appreciated,thanks!
k-20 is offline   Reply With Quote
Old 07-11-2006, 08:28 AM   #2
k-20
Re: strange noise
no ideas?
Old 07-11-2006, 08:44 AM   #3
1969K10
1969K10's Avatar
Re: strange noise
Really sounds like the pilot bushing for the tranny into the back of your motor...
1969K10 is offline   Reply With Quote
Old 07-11-2006, 05:47 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: strange noise
Sounds like the through out bearing. When you push in the clutch it puts preasure on the bearing and the noise usually goes away then...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-12-2006, 07:07 AM   #5
Re: strange noise
It could be the input shaft bearing,too.If clutch action affects it,that`s where you`ll need to look.With the pedal depressed everything is held tight to eliminate any extra tolerance.
