Old 04-28-2002, 02:49 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Post ARB Air Lockers???
Does any one know anything about these things? It sounds like a good idea. I have a 1970 C-20 Camper Special and I have no idea wether it would fit or not. If it does what it says i definatly wanna get one. Thanks
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 04-28-2002, 03:10 PM   #2
Mike C
Mike C's Avatar
Post
It does EXACTLY what it says it does. However, In 99.9% of cases, especially if you drive a lot on the street or the drag strip, you'd be better off with a limited slip. The ARB is an excellent unit expecially well suited to the off-roader.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-28-2002, 03:13 PM   #3
HotRod929
HotRod929's Avatar
Post
So you would not recomend it for a daily driver truck that likes to burn rubber and put those little imports to shame from time to time?
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 04-28-2002, 06:59 PM   #4
imdarren
imdarren's Avatar
Post
Mike,
I thought the point of an ARB Air Locker was that it IS a limited slip when switched off, and a locker when switched on? To me this would be PERFECT for a daily driver / weekend warrior. Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-28-2002, 08:00 PM   #5
Beast388
Suburbans RULE!
Beast388's Avatar
Post
The ARB Air Locker is completely locked, like a spool when engaged and completely open when disengaged. They are very expensive like Mike C mentioned and probably more suited for the off-roader.
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 04-28-2002, 08:04 PM   #6
Mike C
Mike C's Avatar
Post
The ARB is an open diff when switched off and it is a spool when switched on. Zero differentian or 100%. NOT what you want in a streeter. Go with a limited slip for the street. I like the EAton, but the Trak Lok or Power Lok (4 pinion) is excellent if you have a Dana 60.
64 Corvette Coupe
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-28-2002, 08:22 PM   #7
imdarren
imdarren's Avatar
Post
Mike,
My bad. Sorry. I don't want to confuse anyone on the board. I retract my uninformed statement. Darren
Washington State
Old 04-28-2002, 08:30 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Here is there site. http://www.arb.com.au/arb_air%20locker.htm
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
