07-15-2006, 12:51 PM | #1 |
Electrical problem HELP!!!!!
Hi..
I was trying to test the new installation of my cargo light, since my truck is in the shop since 2 years ago the battery cables remain disconected, yesterday i tried to connect the battery cables in order to test if there was power in my cargo lamp but i did a mistake, i switched the + cable to the nehative pole and viceversa, a few seconds passed and the resitence wire a 16ga black wire started to burn, quickly i unpluged the cables but the dammaged was aready done, i burned the fuse wire. So i have some questions 1. Can this happen?, or is something i have wired wrong (i know i did wrong with the bttery cables, but is this normal when you switch your battery cables? 2. How can i replace the resitance wire, this wire runs from the junction block near to battery and is spliced to a 12 ga red. 3. It is better if i just replace the restance wire with a fused circuit? 4. did i damagged the rest of the wiring harness? Thanks |
07-15-2006, 02:53 PM | #2 |
Re: Electrical problem HELP!!!!!
Ii i change the resistance wire with a fused circuit, what kind of fuse do i need to use?
07-15-2006, 03:49 PM | #3 |
ttt
07-15-2006, 03:58 PM | #4 |
you need to run a resistor in your ign circuit to lower the voltage to your points or they'll be burning up on a regular basis every 50miles or so// it's also possible that you damaged the altenator voolt reg and the starter
07-15-2006, 08:13 PM | #5 |
its all about the +6 inches
that is not a resistor wire you are talking about, it is a fuseable link.
A fuse would work, but could be prone to popping, look for a slow burn fuse, or, just replace the fuseable link with a fuseable link. you shouldn't have damaged anything else, that's what it is there for, to protect everything else. |
07-15-2006, 11:47 PM | #6 | |
mine was replaced with a piece of wire i put a 40 amp fuse in mine been about 3 months no trouble yet and mines a dd
07-16-2006, 03:10 AM | #7 |
40 amp is a little high, I would use a 30 amp myself, that is more allong the lines of what actually rolls through that wire.
07-20-2006, 03:03 AM | #8 |
Thanks, i will try to look for specification on this 16 GA fuse link wire, i will let you know what is the specific fuse i can use in place of the wire.
10-15-2006, 04:19 PM | #9 |
I have not found the answer yet...
Any advise??? |
10-15-2006, 04:30 PM | #10 |
That wire should have a fat place on it about 1" or 1 1/2" long. That is the fuseable part of the wire that burns when overloaded. Look on this fat part and there should be a # telling the amp or saying fuseable link.
'07 G6 Wife's car '00 Malibu stock, just a parts getter. '99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
