Old 07-19-2006, 12:02 PM   #1
dstrbd71
dstrbd71's Avatar
decoding the numbers on the frame
I am looking to find out what year my frame is. The cab vin seems to come back as a 1968 3/4 ton V8. It has a small back window. 1 more thing, can you find out the year for box and bed? http://67-72chevytrucks.com/vboard/i....gif:confused:
1967 Chevy Stepside Shortbox
1995 Chevy Silverado 4X4
1956 Chevy 210 post Delray
dstrbd71 is offline   Reply With Quote
Old 07-19-2006, 12:40 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: decoding the numbers on the frame
Look on top of the frame rail near the steering gear, and under the cab on the left side on top. Might need a mirroe to see that one. Should start out the same as the trucks VIN or end the same....cant remember.
EDIT - Just found a pic of my frame. The numbers under the cab end the same as the VIN... Year, Plant, then sequence number.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-19-2006, 12:55 PM   #3
dstrbd71
dstrbd71's Avatar
Thumbs up Re: decoding the numbers on the frame
Thanks for the info. I'll try looking for the numbers. You say on top of the frame drivers side under cab?
Old 07-19-2006, 01:04 PM   #4
glock35ipsc
Yes, also on top of the frame, drivers side, just behind the steering gear. This one will be easier to find. Pop the hood and look, stay clean!
Bob
Old 07-19-2006, 03:10 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Can you get a photo of your VIN plate? You may have the one truck everyone says is real, but no one can provide.
Old 07-19-2006, 03:50 PM   #6
glock35ipsc
Ohhh Andy, you could be on to something there. I didn't put the "small window" and "68" together
Bob
Old 07-19-2006, 03:52 PM   #7
glock35ipsc
Are you talking about the yellow stepper in your avatar pic? If so, is it original, at least the steel metal? Cause if so, it has 67 fenders front and rear.
Bob
Old 07-19-2006, 04:06 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
to stir up the pot some more.... I thought all 3/4 tons were longbed fleetsides only? (with the exception of the 9.5' stepside and longhorns?) The truck in the pics looks to be a shorbed stepside. Correct me if I'm wrong Andy
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-19-2006, 04:19 PM   #9
Longhorn Man
You are right and wrong.
The 9 foot was a one ton only truck.
The 3/4 ton was avalible in both fleet or step side, most with the 8 foot box, mid year into was the 133 inch wheel base Longhorn.
Or... you could get it with no box at all.
Here is a pic of the location for the partial VIN on the frame. You pretty much won't be able to see the one under the cab.
Old 07-19-2006, 04:21 PM   #10
67ChevyRedneck
Soooooo, were there any SHORTBOX 3/4 tons?
Jesse James
Project "On a Dime"
Old 07-19-2006, 04:23 PM   #11
Longhorn Man
In 67 - 72, off the factory production line.... no.
Some of the crew cab conversions used chopped down beds.
Old 07-20-2006, 02:09 PM   #12
dstrbd71
dstrbd71's Avatar
yes we are talking about the truck in the picture. I just got it about a month ago. I've been trying to decode cab, frame, motor, fenders, etc.
I wasn't sure about the cab, I thought it was a 67'. The title says 68'. I am sure the truck isn't original because the cab is registered as a 3/4 ton and its sitting on a 1/2 ton frame. I will try to get some pics of the vin tag on here. This site has been so helpful, Thanks for all the info!!!
Old 07-20-2006, 02:13 PM   #13
glock35ipsc
Be sure to include the VIN tag rivits in your pic. Were you able to find the numbers on the frame rail?
Bob
Old 07-20-2006, 03:18 PM   #14
dstrbd71
dstrbd71's Avatar
I found the frame numbers. they are 7Z144133. Does that sound right? How do you get pictures on here?
Old 07-20-2006, 03:23 PM   #15
glock35ipsc
That says then that the frame is a 67, and was built at the Fremont plant.
Pics - Look for a button named "Manage Attachments" under the window where you type your reply.
Bob
Old 07-20-2006, 03:51 PM   #16
dstrbd71
dstrbd71's Avatar
its telling me file exceeds forum limit?
Old 07-20-2006, 03:56 PM   #17
glock35ipsc
Pic is too big then.. Email it to me if you want, and I will resize it and post it.
Remove the AT and replace with @ - glock35ipsc AT netscape.net
Bob
Old 07-20-2006, 04:00 PM   #18
dstrbd71
dstrbd71's Avatar
:banghead:
Old 07-20-2006, 04:08 PM   #19
dstrbd71
dstrbd71's Avatar
OK. I think I got the pic sent to you. ( I hope it worked)
Old 07-20-2006, 04:10 PM   #20
Longhorn Man
So, we know your cab is a 67 becouse it is a small window, a 67 frame, all 4 fenders are 67...
Now, all you need to do is figure out WHY the data plate was replaced...
Old 07-20-2006, 04:11 PM   #21
dstrbd71
dstrbd71's Avatar
if that didn't work. I will put the pic under my profile.
Old 07-20-2006, 04:30 PM   #22
dstrbd71
dstrbd71's Avatar
I had to remove a couple layers of paint to make it readable in the pic. 1st yellow, 2nd black, then clean with red behind plate.
Old 07-20-2006, 04:37 PM   #23
Longhorn Man
That VIN tag has been installed by someone other than the assembly line. *swapped VIN tag*
You can tell by the perfectly round rivit heads. They are supposed to be what's called a rose bud rivit.
Here's the VIN off my old 69 GMC, notice the rivits.
Old 07-20-2006, 04:40 PM   #24
dstrbd71
dstrbd71's Avatar
how can you tell the difference between 67' and 68' fenders?
Is it the reflectors on the front? Mine have been filled in. Drivers side is aftermarket fender.
Old 07-20-2006, 04:45 PM   #25
Longhorn Man
that's right, 67 had no side markers/reflectors, 67 did.
