Help with tfer case...can someone
maybe clue me in to where my transfer case MIGHT be leaking from? I know you can't tell much from this picture but it would be better than my guess. You guys are the experts around here. If it's just a gasket...where can I get the gaskets or seals for this thing? I'm a computer guy so any help that yall can give me or if someone could point me in the right direction, I'd really appreciate it. Thanks.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon Last edited by Blizz; 07-16-2006 at 09:44 PM. |
![]() Join Date: Apr 2000
Re: Help with tfer case...can someone
my first place to check fro mthe pic is where your speedo cable screws in the the ratio box on the side of the case looks like you cable might be pulling on it a little and that could cause a leak.
i would wipe it down good then drive it a little the check it again. good luck jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
You really shouldn't have any leaks of Gear Oil above the fill bolt. If you are experiencing leaks that high up I would guess that you have ATF in there from your tranny. A brand new set of Tcase gaskets will succomb to an overfilling of ATF. Those seals at the top aren't really meant to have fluid against them at all times.
You may have to pull out your tcase and redo that big O ring from the tranny to the Tcase. Since you have the Tcase out I would have it resealed as well. You can do it on your own but you have to pull the gears apart.
Rob "RunTMCfan" |
#4 | |
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
Clean it all off, and see where a fresh leak starts from. Its hard to tell after they've been driven a lot becuase the fluid gets thrown everywhere.
Its probally leakin from the snout of the transfercase, my 82' started there right before i sold it. -Cameron also check if your tranny is leaking, its entirely possible its throwing fluid back onto the transfercase. I had my father's dealership do a oil change on my truck and they dropped the oil filter, which cause it to leak, by the time i got home and realized it was leaking i had oil covering the entire undercarrage, from enigine to rear driveshaft.
1972 Dark blue, Cst, Highlander Last edited by ClassicStyle; 07-18-2006 at 11:44 AM. |
If it is leaking from there, what kind of repair would I need to do? Are we talking gaskets and seals here or something worse?
Check out GMTrucks.org
Unless the case is cracked, to fix any leak you are looking at gaskets and seals. I got my rebuilt kit from Transmission Exchange (http://www.txchange.com/).
Pete |
![]() Join Date: Mar 2003
Looks like he is full of atf, look at the color of the oil dripping off the speedo parts. Pull the FILLER plug out and see what happens. May have to pull the case to install new seals in between the 2 units. At that point I would reseal the whole t-case myself.
excellent advice yall. thanks a bunch. how do i find out what tranny i have?
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Looks like a T350 to me - that's what most Blazers came with...
Check this link for help in sealing the speedo cable... This guy is over on coloradok5.com - very cool website... http://www.norcalbigdawgs.net/Gallery/album49
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
#12 | |
bump
Future TOTM Winner
This is an old thread by Blizz, but I am having the same problem. Currently the transmission and Tcase are pulled out of the blazer and unbolted from one another (th350/np205 - 27 spline with drive sleeve) I believe the seal in question is actually in the adapter plate on mine. Do I get to this by pulling everything out from the transmission side and work my way back? I know this is a technical question and could use some pictures, sorry.
Blizz, how did yours turn out?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#15 |
I'm having the same problem also (tranny fluid in the tcase). I put new gaskets and seals in it a few years ago but it didn't help. I plan on taking the trans. and tcase out again this winter to inspect and reseal again. Is there anyone that has a diagram that shows where all the seals and o rings go, I'm thinking I might have missed something when I did it the first time.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#16 |
Cereal Killer
to replace the seal in the transfer case adapter just unbolt it from the tranny and bolt off the transfer case...there are two seals inside the adapter.
#17 |
Future TOTM Winner
Thats the way it looked to me. Is there anything that has to be pressed in or out? Im gonna try it later today or tomorrow.
