07-31-2006, 09:19 PM | #1 |
No wide open throttle!!
After installing my edelbrock carb on my truck I took it for a drive,It seems as if it doesnt have wot. Any suggestions what to do?
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
07-31-2006, 10:20 PM | #2 |
its all about the +6 inches
Re: No wide open throttle!!
first you need to verrify this to be true. The carb might be needing tuned, and just doesn't make the power that your last carb did.
07-31-2006, 10:28 PM | #3 |
Engine OFF. Have someone in cab floor the pedal. Look down in front 2 barrels of carb and see if throttle blades are straight up and down. If not , adjust linkage . (what bracket did you use to mount cable?)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-01-2006, 09:29 AM | #4 |
Thanks yall,
The carb seems to be set up right, jhow66 I used the factory throttle cable bracket.Do I need to get an after market bracket?
08-01-2006, 09:53 AM | #5 | |
08-01-2006, 10:32 AM | #6 |
O.K. I guess I am going to make another trip to the parts store.
08-01-2006, 11:13 AM | #7 |
on mine i found out the cable from the pedal to the carb should have a stopper on it near the pedal, and my pedal wasn't pulling the cable far enough because of all the slack in the cable.
08-01-2006, 01:24 PM | #8 |
good tip matthufham. I will check it out.
08-01-2006, 07:28 PM | #9 |
laying low
Not sure how the edel carb is made but a quadrajet secondary will not open until the choke is open all the way. Also the secondary air valve of a quadrajet has an adjustable spring to speed up or slow down the opening rate of the air valve. Makes for a smooth transition from 2 brl to 4 brl. The edel may have some of the same adjustments.
08-01-2006, 09:45 PM | #10 |
The LuvShack Garage
WOW, Great advice 66
08-02-2006, 01:05 AM | #11 |
Oil trash and damn proud of it
also, another piece of advice with Edelbrock stuff.... when I installed Edelbrock's Performer Intake Man. and Carb on my 350, I couldn't get my secondary butterflies to open very much at all... figured it out that the manifold didn't let the carb open WOT, had to buy a spacer for it, after which it did work. One more way Edelbrock can milk you for money.
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ |
08-02-2006, 09:03 AM | #12 |
69-350 Which intake were you using, Mine is a performer, I havent been able to work on it yet to see whats happening so I'm collecting all this info in advance.
08-02-2006, 06:38 PM | #13 |
I just used the regular old Edelbrock Performer intake manifold (square bore I think) with their #1406 600cfm Electric-choke carburetor. When we tried to open her up, she would stop cause she was hitting the secondaries on the manifold's bore about 3/4 throttle or so. So I had to run to the parts store and buy a 25 dollar spacer, after which it worked. And don't forget to put gaskets in there, after she could run wide open, with a giant vacuum leak because somebody forgot the gasket between the spacer/carb it ran so wide just starting it that it floated the valves. I think I've got it down now, the beast is timed perfect, the carb is tuned perfect (thanks to a buddy and his college auto-techeducation and his timing light) and it's just too bad I've got to tear the motor apart to replace some bad rings on the passenger side.
08-03-2006, 09:51 AM | #14 |
Sounds like the same one I'm running. I dont think mine is hitting though,But I will check in a little bit.
08-03-2006, 10:20 AM | #15 |
you should do that. if I'm not mistaken, I think the intake is a square bore, and the carb is meant for a spread bore(?) Either way, I bought an Edel intake and carb, and they didn't bolt right up to each other. What a deal there, huh?
