Old 07-31-2006, 11:29 PM   #1
Rod
72 Blazer chassis 4x4 for sale or pieces I need
I got 72 blazer 4x4 chassis for parts for a project. I really only need the front set of brackets as I'm trying to get parts for a 4x4 conversion on a 2 wd.
Now before I carve this frame up I thought I'd ask if anyone wants this as it is in exchange for the brackets and some coinage.
The frame is a 72 blazer 4x4 frame...the windshield frame has been cut off..so its a tub with the rear diff still in tact. 72 V8 vin still there also. The transfer case and engine cradle have been removed. It's basically a 4x4 frame and rear diff.
Thought I'd ask before its carved up...and if its carved,,well theres some brackets off the rear diff I guess I could sell..yes there's one carpet strip from the back and the mounts for side panels in the rear. Jack spring and mounting brackets.
I'd let it all go for $250 and the brackets I need..or I'll use this chassis and sell off what I can.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-02-2006, 08:29 PM   #2
Rod
Re: 72 Blazer chassis 4x4 for sale or pieces I need
Make an offer if one comes to mind.
Old 08-02-2006, 09:37 PM   #3
tbreaden
do you have the rear upper shock brackets?
tbreaden is offline   Reply With Quote
Old 08-03-2006, 11:42 PM   #4
Rod
There on there for now...if I carve the frame up I'll let you know.
Old 08-14-2006, 10:23 PM   #5
69TowRig
You mentioned a carpet strip, still have it? How's it look?
I could really use a good set of rear bumper brackets, so doofus stick-welded mine to the frame rails and I will surely ruin them when I cut them back off. I need all 4.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-14-2006, 11:31 PM   #6
Rod
This one still has the curved rear frame horns ..so no brackets...bumper bolted to the frame.
I still havent carved it yet..I may go look at it this weekend coming....I left it at a friends place for a bit.
Old 08-15-2006, 07:34 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
What kind of shape are the bucket seat mounts in. ( The ones that are spot welded under the tub )
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 08-15-2006, 08:30 AM   #8
Rod
This tub has had the windshield frame firewall back to the rear floor removed and sold by PO.
