Need Help Removing Instrument Bezel
OK, so I am replacing my bezel with a refurbished one and have ran into a snag and cannot get the light and windshield wiper knob off. How do you take off these knobs so that you can get the bezel off? Thanks in advance.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
Sophomore Member
![]() Join Date: Jul 2006
Re: Need Help Removing Instrument Bezel
the windshield wiper knob has a set screw, you need a small flat blade screw driver. look on the knob close to the dash and you should see it. once the knob is off you unscrew the chrome part, usually can be done by hand, i had one the other day too tight and had to put something in the holes inside and tap a little to get loose. the headlight is a little more difficult. you have to pull it out like the lights are on and then reach up inside the dash to the switch itself and it has a little button on top of the switch that you have to push and pull the switch at the same time and it will come out. once it is out the chrome part unscrews as the windshield wiper does. hope this helps and my instructions are ok.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
disconnect battery ground
pull headlight knob to on reach up behind dash and there's a button with a spring you push in hard on and the knob pulls out with the rod wiper knob has a set screw |
Thanks a lot guys... got it off with ease and the new one on.
