Old 08-01-2006, 05:42 PM   #1
70heavyhalf
rear spring bushing help
I have a 70 2wd 1/2 ton w/leaf spring in the rear not coil. i ordered bushings from energy and they are to big to fit in the sleve. the main eye outside diameter is 1 1/4 in long. does anyone know of a company that has what i need.
darin
______________
70 c/10
70heavyhalf is offline   Reply With Quote
Old 08-01-2006, 08:17 PM   #2
JimKshortstep4x4
Re: rear spring bushing help
If I am reading your post correctly the sleeve from the old bushings is still in the spring eye and it should come out before installing the new bushings.
JIm
Old 08-01-2006, 09:15 PM   #3
70heavyhalf
the sleeve is out, just when i got my new bushings they were to big they are 1.5 in" in dia. and the sleeve is 1.25 in" in dia. the ? is does anyone know of a company that makes a bushing kit that the bushing od is 1.255 in"
darin
________________
70c/10
Old 08-02-2006, 10:38 AM   #4
legends
Try NAPA they offer several diameters.
legends is offline   Reply With Quote
Old 08-02-2006, 06:25 PM   #5
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
hope this helps
i have a 72 1/2ton c-10 lwb chevy with heavy duty rear leaf springs.i tried everywhere online and with vendors on the board to find new bushings with no luck.well i finally found them in stock at local napa parts store.id seen a post on here along time ago that someone else had the same problem.tha napa part # is 274-1185 for$9.72 each
at first they gave me part #274-6459 which may have been for regular springs but they was a little to small for the heavy duty springs.
hope this helps someone
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 08-02-2006, 06:27 PM   #6
72shadetree
KEEP ON TRUCKING
if i remember right the ones that i needed was 1.25
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 08-02-2006, 07:01 PM   #7
70heavyhalf
hey thanks guys ill try them
darin
_________
70 c10
