Old 08-04-2006, 10:25 PM   #1
krue
Designated A-hole!
krue's Avatar
Need quick answer on 700R4
My bro is plumbing the cooler to his 700R4 and needs to know which fitting on the tranny is supposed to be the line to the cooler and which is the return.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-04-2006, 10:43 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Need quick answer on 700R4
I don't think it matters which one you use.
Hart_Rod is offline   Reply With Quote
Old 08-04-2006, 10:48 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
I ran bottom port to bottom, top to top. I did this after looking at a buddie's 87 chevy truck with a 700r4...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-05-2006, 02:10 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
From TCI's site.
Half way down the page.
Upper port is the RETURN
Lower is out or feed to cooler.
http://www.tciauto.com/tech_info/cooler_fittings.htm
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-05-2006, 04:27 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is some info I c/p from a website on the internet and a pic I saved from another site.
Transmission Cooling: You must have a transmission cooler in your radiator regardless of what someone has told you for the transmission to last. Auxiliary coolers are just that, in addition to. Water cools better (faster) than air always, period. The transmission fluid comes directly from the torque converter at a much higher temperature than the water in your radiator and is cooled to the water temperature fast. Then it goes to the auxiliary cooler to be cooled far below the water temperature. If you don't need a cooler in your radiator why does GM spend all that money doing so? If you wanted to cool a red hot piece of steel fast would you stick it in water or air, see the point. Your transmission will run cooler with a lock-up converter. This is more important with stall speeds of 2000 RPM or higher.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-05-2006, 06:31 PM   #6
krue
Designated A-hole!
krue's Avatar
Thanks, vettevet, he's doing the aux cooler then radiator cooler, so we were trying to figure out how to get the flow in that order.
www.daveramsey.com
