Old 08-09-2006, 10:35 AM   #1
Nightrider
Nightrider's Avatar
FS-6 spd trans, turbo,driveshaft...
Was going to keep this stuff for a project ( one day), but I'm overloaded now!6sp manual trans out of 03 dodge,2500. Had the cummins in it,58k miles. With bellhousing and shifter-1250.00 Complete turbo, intercooler,tubing 600.00. Drive shaft, sb ,4dr for the above 250.00. 100 miles south of DFW,Texas
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 08-09-2006, 07:29 PM   #2
Fordeater
Junior Member
Fordeater's Avatar
Re: FS-6 spd trans, turbo,driveshaft...
that is a steal for that transmission, wish i had the money.
Fordeater is offline   Reply With Quote
Old 08-10-2006, 05:00 AM   #3
Nightrider
Nightrider's Avatar
Figured I'd put on here first before the truck trader. That trans is very heavy duty,and I mean heavy!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-10-2006, 07:14 AM   #4
junkyardjohn
junkyardjohn's Avatar
Nightrider.... Does That Trans Have The Provision For A P.t.o. ? I Would Love To Have A 6 Speed In My 69 Tow Truck. Also Shipping To 42501 Somerset Ky. Are Chevy Bellhousings Available For That Tran.s Or Do I Have To Go The Adapter Plate Rought?? I'm Very Very Interested. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-10-2006, 09:07 AM   #5
Nightrider
Nightrider's Avatar
I have no idea about any of your questions. I guess you would have to seek them outon a dodge diesel forum.NOt sure the weight, who do you recommend I check with for shipping?
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-10-2006, 11:41 AM   #6
junkyardjohn
Ok... I'll See If I Can Find The Answers To The Bellhousing & Pto Issue. Does It Have A Removable Bellhousing?? (bolted To The Tranny) I'm Assuming It Is A Nv5600?? Is This Correct?? Last Summer I Helped A Buddy Of Mine Put An Auto-trans. In His Dodge 1 Ton With A Cummings In It. He Bought A Jasper Tranny, & It Was $65 To Ship It By Ups From Jasper Ind. To Carson City Nv. Undoubtably It Is More Now, But You Are About 1/2 The Distance. Do You Have The Clutch Disc & Pressure Plate?? (i'll Need Em For A Core) . Is This A nv5600?? & How Much Does It Weigh?? Thanks John
junkyardjohn
DON'T RENT U-HAUL
Old 08-10-2006, 12:29 PM   #7
junkyardjohn
NIGHTRIDER.... WELL ADVANCE ADAPTERS DOES NOT MAKE ANY ADAPTERS TO FIT A NV5600 TO A CHEVY MOTOR. IT SEEMS THE BELLHOUSING IS PART OF THE CASE. IT DOES HAVE A PTO PROVISION THOUGH. THEY SAID I'LL HAVE TO SETTLE FOR A NV4500 (5 SPEED) OR A OVERDRIVE UNIT FOR MY OLD 4 SPEED. I CALLED SEVERAL TRANNY GURUS & IT'S ABOUT $2400 TO REBUILD ONE. I WISH WE COULD DO SOME BUSINESS WITH IT , BUT I'LL HAVE TO PASS.
HERE ARE THE SPECS. ON IT.
NV5600 6 Speed Specifications:
Case:......Cast Iron
Bellhousing:......Aluminum Alloy
Torque Rating:......550 lb.-ft.
Gross Vehicle Weight:......16,000 lbs.
Gross Combined Weight:......26,000 lbs.
Transmission Weight:......360 lbs.
First Gear Ratio:......5.63-1
Second Gear Ratio:......3.38-1
Third Gear Ratio:......2.04-1
Fourth Gear Ratio:......1.39-1
Fifth Gear Ratio:......1.00-1
Sixth Gear Ratio: .073-1......(Overdrive)
Reverse Gear Ratio:......5.63-1
Oil Capacity:......9.5 pints
Oil Capacity with optional filter:..10 pints
Recommended Lubricant:.....Texaco STF
Input Shaft:..10 Spline, either 1.25" or 1.375"
THANKS ANYWAY...... JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 08-10-2006, 02:03 PM   #8
Nightrider
Nightrider's Avatar
sorry it won't work for you. it would be best for someone who already has one and needs a spare.
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-10-2006, 07:20 PM   #9
Fordeater
Junior Member
Fordeater's Avatar
I found this article about companies making a new front cover/bellhousing for the nv5600. I couldn't find out prices or anything, but here is the article.
http://www.4wheeloffroad.com/techart...stom_swap_kit/
Old 08-10-2006, 09:21 PM   #10
Nightrider
Nightrider's Avatar
Wow!, very cool. thanks for the infor.if I read any more I might want to keep it!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-13-2006, 09:37 AM   #11
Nightrider
Nightrider's Avatar
this is a steal on this trans. nobody interested? wow. going to evil-bay.
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-13-2006, 05:05 PM   #12
1967k30
1967k30's Avatar
I wish we were all closer. I have {well my brother does} a rebuilt NV4500 {GM} with zero miles we are putting in his 67' K20 Cummins. We could trade and John could have a NV4500 and my brother could have the NV5600. Oh well,we have already spend enough $$$$ for the bellhousing to mate the GM NV4500 to the Cummins.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 08-13-2006, 09:46 PM   #13
junkyardjohn
An Nv4500 Would Be Great For Me. Especially A Rebuilt One. Lets Do It..... I'll Play. I Would Like Either A Nv4500 (with A Chevy B/p Bell Housing) Or A Gear Vendors Overdrive. John
junkyardjohn
DON'T RENT U-HAUL
Old 08-13-2006, 09:48 PM   #14
Nightrider
Nightrider's Avatar
Don't you know thats how it always goes!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-14-2006, 08:27 AM   #15
TP from Cntl PA
TP from Cntl PA's Avatar
Is it for a 4x4 or a 4x2? I really wanted a ZF 6 spd for mine, but the price on this NV is tempting.............Just need a 4x2 version.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 08-14-2006, 08:30 AM   #16
Nightrider
Nightrider's Avatar
2 wd
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-14-2006, 08:33 AM   #17
TP from Cntl PA
Any idea on the price of shipping to zip 17702 WITH the driveshaft..........Overall total.
Old 08-14-2006, 08:43 AM   #18
Nightrider
Nightrider's Avatar
who would you suggest I check with? A preferred freight company that has a hub near you?
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 08-14-2006, 08:47 AM   #19
TP from Cntl PA
CCX, Yellow, Estees, probably there are more that I am not thinking of.
Old 08-14-2006, 09:40 AM   #20
Nightrider
Nightrider's Avatar
sent PM
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
