![]() Join Date: Mar 2006
Center/Drag link..where to find
Ok, ive looked on the internet until my eyes about popped out of my head
1986 C10 - LWB, 305/700r4, posi, vortec heads |
![]() Join Date: Aug 2003
Re: Center/Drag link..where to find
Pretty much a non-wear item unless the truck or other related front end items were abused.
No abuse that I can see. Im a novice mechanic and someone I consider far more experienced than I scoffed when I told him I hadnt planned on replacing it. Thanks for the tip Uncle!
Not reproduced to my knowledge but very available in any recycle yard. I have one for a 70 coming off for a complete 72 front upgrade. Like Uncle says, they don't wear out--usually they get bent up from some jerk hooking up onto one to tow a truck onto a trailer or ?
Be aware that not all 1/2 center links are the same. I ran into an issue this last weekend and discovered that there was a difference between one that came off of a 72 vs one that I had from a 70... The holes that the tie-rods mount in were different by almost .100". Not sure why but it is what I discovered.
That being said I have the one from the 72 all cleaned up a painted ready for install. I'll get you the measurements on the tie-rod holes and post a pic later.
78 C10 LWB Super Cheyenne |
Much appreciated jimmy. I do indeed have a '70 chassis but the new gear I have came with a disc conversion kit and im pretty sure its the later model stuff.
![]() Join Date: Apr 2005
Kris,
I think you need the one from a 71/72, unless your stuff is new than that. Have you checked at Butler's? If they don't have one, my buddy on 9 mile might. Rob EDIT: Any ET on the Caprice disection?!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-15-2006 at 09:50 AM. |
