Project 7dos
Whats Going On????!!!!!
Yesterday after school I went to my truck, and I heard a rocker loose in the head so i took the valve cover off when i got home, found the loose rocker, tightened it, then everything was fine. THEN AFTER SCHOOL TODAY!!, I went to it and started it up and the same thing with the same rocker????!!!??? what is that??? is something wrong???
Ideas?? Thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
While you have the valve cover off, lay a straight edge (or something close) across the rocker arm studs. I bet you'll find one thats pulling up on you. Each time you adjust the rocker its fine until that rocker pulls the stud up a bit more.
If this is the case, you can buy oversized studs, knock a new one in and your all set. The other possibility is a lobe going flat on the cam which is dishing out the bottom of the lifter (causing more and more valve lash) If it's still running ok after the valve adjustment, chances are the cam/lifters are in good shape. |
could be a couple of things...bad lifter(doubt that) rocker stud is pulled up,check the hieght compared to others or the most likely cam lobe going flat..you might want to look at the pushrod..see if the ends are messed up, also check the rocker where the pushrod goes into..if it turns out to be the cam lobe..dont drive it ...the cam guts do very bad things to bearings
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
boy zkast..you sure are smart....lol.. we must of posted at the same time
lol same answer at almost the same time
Truck'n the alcan
Could be a couple of things. Rocker stud is sliping, bent push-rod, collapsed lifter. I'd bet it's a pulled rocker stud. To check lay a straight edge on the top of the studs.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van |
Truck'n the alcan
Must be some fast fingers out there. All good advise.
![]() Join Date: Sep 2000
it might be just a bad nut that works its silf lose
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
i had an old pontiac one time that i had to replace the nuts on the rocker arms. no problems after that. i think they are tapered nuts and after a few times on and off they dont stay tight any more.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club Last edited by Jwill41; 10-19-2002 at 03:29 PM. |
