Old 08-29-2006, 09:34 PM   #1
crawdad
crawdad's Avatar
Question about differential options
One of the options on the option sheet for my truck is code "G80 - Locking Differential". Exactly what kind of locking differentials did GM put in the trucks? Is it a straight positive traction or is it some type of limited slip? Just curious. I just picked this truck up. It has 2.73 gears in it with supposedly a locking differential, and a 700R4 tranny. I would have thought that with the 700R4 it would have had a lower geared differential. I got great gas miledge coming home with it. I wonder why?
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 08-30-2006, 09:13 AM   #2
crawdad
crawdad's Avatar
Re: Question about differential options
Well after doing some more searching it would appear that a limited slip and a positraction unit are both the same. It also looks like GM calls theirs a positraction unit when it is actually a limited slip. Does this sound correct?
Old 08-30-2006, 09:26 AM   #3
Prerunner1982
Prerunner1982's Avatar
I know in the military trucks the stock locking diff is called a Gov Lock, I believe it to be the same in civilian trucks as well. Havent heard anything really good about them, but I am sure they work just fine under normal use.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-30-2006, 05:22 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
G80 is GM's designation for a limited Slip differential. They Name they gave it was Positraction. Prior to about 1980 they used Eaton clutch diffs afterwards they went to Eaton Gov-Locs. Either will server you well in normal situations.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-30-2006, 07:29 PM   #5
crawdad
crawdad's Avatar
Thanks, appreciate it.
Old 09-03-2006, 10:41 PM   #6
mntoy
How did you determine that your G80 rearend had 2.73 gears?
mntoy is offline   Reply With Quote
Old 09-04-2006, 01:07 AM   #7
crawdad
crawdad's Avatar
It was stated on the RPO list in the glove box.
