08-31-2006, 12:51 AM | #1 |
SUPPOSED to get Viair 400...got 380 instead
Ok well kinda pissed off but help me out here...
I ordered a 400c,tank,valve,gauges from a local shop. Had to order from the US, parts got held at the border slightly late, not a huge deal. Told me to call him daily, i did for a full 7 days. **** gets here tells me to come get it, when i show up he has a 380C there for me in chrome, instead of the 400C plain steel. They were on backorder for who knows how long. Sooooooooo for my needs, 5 gallon tank, 4 path, 64 chevy 1/2 ton i wanted a compressor that would fill fast and shut off, 400c is the one i wanted, didn't see my self on the switches all the time, wanted to pull up to where i park, dump it, when ready to leave, fill it. 380c is 100% duty cycle 200 psi, but waaaay less CFM, fill time from 110-145 is almost a full minute longer, from 1:30 to 2:26. SHould i be pissed off, or put up with the longer fill time to possibly be able to hit the switches more, the fact is my 5 gallon tank will drop to 110 so fast that i cant really "play". Help me out...should i look locally for a 400c, or stick with my chrome 380C. Oh and he forgot to order my tank...can be had locally in two days or less.
1964 - LWB 350 TPI Fuel Injection On airbags |
08-31-2006, 11:02 PM | #2 |
belly dragger
Re: SUPPOSED to get Viair 400...got 380 instead
The 380 gonna run alot longer than a 400 series comp. Did he charge you the same? We normally have a fairly large stock of comps at the shop. If you want give me a call tomorrow 1 888 275 2588.
Rob |
08-31-2006, 11:27 PM | #3 | |
And those Viair guages, the just have a threaded nipple on the back side, i assume i have to use compression fittings, but the ones i used on my bags had a sleeve you slid into the tubing and then the ferrule and then the sleeve nut. And the gauges are 1/8" line correct ??
09-05-2006, 09:26 PM | #4 |
You can use 1/8" or 1/4" for the gauges. I always have a hard time finding fittings for the 1/8" line locally. 1/4" compression fittings you can get at any home depot or hardware store. the threads on the guages are 1/8 male pipe thread
09-08-2006, 11:33 AM | #5 |
Hey man. I'm in Calgary too. I'm curious what shop you ordered from, if ya don't mind me asking?
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! |
