![]() Join Date: Sep 2005
should i?
i got a chance to go pick up a 305 engine for 350 buxs it only has about 55k on the motor it have hear it runs and it runs strong i am looking at placing ti in my truck it will replace the 307 that is in there now
its all about the +6 inches
Re: should i?
350 bucks for a 305???
Pass. The only thing that motor has going for it is the low miles. I'd expect to pay more liek 200 for it. 305's are a dime a dozen, and there is probably a guy within 50 miles of you with a perfect running 305 hoggin up floor space in his garage willing to give it away. The problem is, locating said dude. |
The LuvShack Garage
Re: should i?
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Re: should i?
You'll gain nothing. Neither motor is great, so why trade one for the other.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
Re: should i?
i got a 305 in mine with a comp 268h cam and flat top pisons. runs good and has good power but if i was gonna build up an engine i'd go with a 350 just because of more cubic inches. i know a guy near walertown that has a couple runnin 4 bolt main 350's for a good price if your interested. kinda off topis, but were you sittin at stop light turnin onto salias creek last friday around noonish? chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's Last edited by 71chevytruckguy; 09-01-2006 at 04:26 PM. |
Re: should i?
I would take that tired 307 and have the lower end rebuilt. When they do have it bored to 4 inch and it will be a fresh 327. Put some 64cc heads on it with a 650 holly and it will be a screamer. Make sure to have it balanced when you do it. I know there is a few more things to do like cam and the right iginition but I put one in my 57 short step I had and It ran like a champ. I had 3.08 gears in the back and in the right conditions (Me not having my foot in the carb) it was getting around 18MPG. I would hold on to that 307. It is a much better motor than that 305. Good Luck.
JRB |
#7 | |
Re: should i?
i need a cheap motor till the start of the year the 307 is knocking pretty good now i start engine class in januray and i can rebuild it i'd like a 350 you know what he asking for them? __________________
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 09-01-2006 at 05:00 PM. |
![]() Join Date: Jul 2006
Re: should i?
There is no replacement for displacement
#9 | |
Gone Fishing
Re: should i?
![]() Quote:
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Happy to be here
![]() Join Date: Mar 2000
Re: should i?
If you can't find another motor offer 200.00 and run it until you can build your 307.
Re: should i?
I may get flamed for this, but I'm willing to bet you can locate a good running 350 in a junk yard cheaper than the asking priceof that 305. It's up to you to prove how healthy it is...BEFORE buying it, but it can be done. And most yards can't tell a 305 from a 350, so you tell them it's a 305 and you might get it even cheaper... but that's not exacly honest. (but they'll stick it to you when they get a chance though)
#12 | |
Aluminum slot wheels rule...
Re: should i?
![]() 350 bucks could buy you a 307 rebuild kit from Northern Auto Parts with all Federal-Mogul stuff, plus whatever other tidbits you need for the motor. (you'll probably have 100 bucks or so left over) |
Re: should i?
the cost of machineing the 307 is running about 11 buxs a hole to bore so that 88 get the block cleaned and checked 15 buxs rebuild the heads another 50 buxs a head thats 203 buxs thats the cheapest i could find here if i could make it till begining of the year i start engine shop and can get the machine work for free
Re: should i?
Why don't you put the truck on the backburner so you don't stave the motor up anymore than what it is, and ride in your F-150 until you can fix the 307. Just a thought.
#15 |
Re: should i?
well i normally would but my dad is driving the f-150 since his car got repoed well i'll have to see if i can find a good used 350 for a reasonble price i may just do that
#16 |
I survived Dead Man's Curve.
Re: should i?
Police impounds... that's where I'm looking. For like the 73-87 trucks, preferrably before they went fuel injected so that way I don't have to deal with finding a carb intake and all that.
If you can find one of those trucks, you can get the 350 (pretty common) AND salvage parts off of the front disc brake and booster setup. THat's my plan, Stan. I mean Dave. ![]()
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() |
#17 |
![]() Join Date: Aug 2001
Re: should i?
I WOULDN'T INVEST SO MUCH AS A GASKET SET IN EITHER ONE OF THOSE POWERHOUSES. THEY ARE JUNK. INVEST THE SAME MONEY & LABOUR IN A 350 & YOU'LL HAVE TWICE THE MOTOR FOR THE SAME CASH & LABOUR OUTLAY. JUST THE .02 FROM A GUY WHO SAW THE INSIDE OF A MOTOR ONCE.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#18 | |
Re: should i?
#19 |
Re: should i?
Yep Once... Maybe Twice. Those Motors Were 180 Horse When They Were New & All The Conditions Were Perfect. After 37 Years??? Maybe 1/2 Of That. Don't Waste Youre Time Or Money. The Boneyards Are Full Of Good 4 Bolt 350 Blocks For Under $100. John
#20 |
Re: should i?
maybe there for under 100 buxs but not here
#21 |
Re: should i?
Well, come to think of it, Classic trucks magazine did a buildup on a 307. It was an original motor from 1968, never been rebuilt. And with a higher lift cam, old-school Edelbrock intake, and a Q-Jet, it made 230+HP and 278lb. ft of torque. Pretty respectable for and original 38 year old engine. When they got done with the motor, they spent 5 grand or so and had 315hp and 330lb ft. WOW!
![]() Last edited by JAKES 68GMC; 09-05-2006 at 09:15 PM. |
