Old 09-05-2006, 09:05 AM   #1
bigbadbowtie
question on cam vs springs
I just picked up a set of fresh 882 heads with a stock replacement valve springs from local shop. My question is... can I get away with a cam thats in the 440 lift range without coil bind. I believe the stock replacement cam is somthing in the .396/.400 lift. I don't think an extra .040 is going to hurt???
Ill check for coil bind but just looking for thoughts...
The heads are going on a fresh flattop 355 and will end up in my 86.
The 180,000 mile 305 is dead tired.
Ray in bama
78 Z28 Camaro,355 roller,10.78@127
86 C10 dog tired 305
bigbadbowtie is offline   Reply With Quote
Old 09-05-2006, 05:42 PM   #2
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: question on cam vs springs
i had some 882's on my 355 1.94, 1.50 valves and 76 cc's well i ran a 268 cam from comp and had no problem i'm thinkin it was like .454 lift it worked fine however i wouldn't recommend going any bigger than that but it was a great camshaft
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-05-2006, 07:44 PM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
yeah, your good , nuf said . crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 09-06-2006, 10:31 PM   #4
jimfulco
Chevy ran as much as .450/.460 lift on standard 3911068 valve springs, the same springs found on 2-bbl V-8's.
jimfulco is offline   Reply With Quote
Old 09-07-2006, 08:22 AM   #5
bigbadbowtie
Thanks guys.. I mocked it up last night and all is well.
Hoping to drop it in next weekend. Im still waiting on headers and the carb shop.
Ray in bama
Old 09-13-2006, 02:20 PM   #6
krazymonkeys24
You could actually run alot bigger cam with the stock springs. I have those heads on my roller 350 with a hot LT-4 cam. That pushes .525 lift with no probs. I went ahead and put in screw in studs, though, just to make sure I didn't knock one loose and may use stud girdles later to even out the tension a little.
krazymonkeys24 is offline   Reply With Quote
