Old 09-14-2006, 08:52 PM   #1
QKENUF4U
QKENUF4U's Avatar
Thumbs up 4-link setup........
do they make a BOLT ON 4-LINK SETUP for our trucks ? i dont have the welder/knowledge to do the whole welding mounts etc. ive looked at all the threads about 4-links but they are all weld on style.
do they make a kit that is just the coil-overs and mounts (top and bottom) that uses the stock trailing arms ??
thanks
lance
QKENUF4U is offline   Reply With Quote
Old 09-14-2006, 10:23 PM   #2
bigjimzlll
bigjimzlll's Avatar
Re: 4-link setup........
They make a coil over bolt on set up..no 4 link that I know of. Heres the link to the coil overs
http://www.classicperform.com/tech_a...coil-overs.htm
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-14-2006, 11:08 PM   #3
68 short step
i dont know if they still sell that, they dont list it any more in there catalogue
68 short step is offline   Reply With Quote
Old 09-15-2006, 12:11 AM   #4
MisterMan
MisterMan's Avatar
no, at least what i have seen. all the trucks i have seen are custom. usally 3 links.... ick.... and usally weld on.... stronger in most cases.
MisterMan is offline   Reply With Quote
Old 09-15-2006, 09:16 AM   #5
QKENUF4U
QKENUF4U's Avatar
thanks so far guys. i emailed them and ask if they still make that kit
Old 09-15-2006, 10:19 AM   #6
68 short step
keep us posted... i too wanna know
Old 09-15-2006, 07:13 PM   #7
QKENUF4U
QKENUF4U's Avatar
they DO NOT produce that kit anymore
Old 09-15-2006, 08:09 PM   #8
junkyardjohn
junkyardjohn's Avatar
I've Had A Couple Of Big Horse Power Pro Street Trucks, & The Stock Trailing Arm- Coil Spring Setup Hooks Up Unbelievably Well. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-15-2006, 09:38 PM   #9
There are back-1/2s made.But,there`s still alt of fab work to work them into the stock frame.It`s only necessary when going with an extra narrow rear/super wide tires where the frame is too wide.
What size are your tires/wheels?
Old 09-15-2006, 09:57 PM   #10
rage'nrat638
rage'nrat638's Avatar
heres my ladder bar set-up on the 85 all welded by the way...and you can see the 350 lbs steel plate bolted in the rear frame rails above the rear end..
thats how you get it to hook...
rage'nrat638 is offline   Reply With Quote
Old 09-15-2006, 09:59 PM   #11
rage'nrat638
one more..or two
Old 09-15-2006, 10:01 PM   #12
QKENUF4U
QKENUF4U's Avatar
i actually looked at it tonight and with my tires i would have to run the coils inside the frame which means i would have to totally rework my exhaust (new a couple months ago) and have mounts welded to the axle tubes/trailing arm mounts and then figure out how to mount them up top (not to hard)
i was really only after the cool factor on this whole setup since i dont drag race/street race or drive the truck all that much to be exact.
Old 09-15-2006, 10:04 PM   #13
pdr510
Junior Member
pdr510's Avatar
I had the classic performance parts coil over kit on my truck for 1 1/2 years. It is to date the biggest waste of money I have spent on my truck. It was $500 plus shipping. It had to be the roughest ride I have ever seen. It might would have worked better on a heavier truck. It did not go well on my '70 stepside. It looked good thats about all. I went back with stock springs and some good shocks and sold the kit on ebay earlier this year. You are not missing out on anything, just my 2 cents.
pdr510 is offline   Reply With Quote
Old 09-15-2006, 10:31 PM   #14
junkyardjohn
RAGENRAT... THAT SETUP IS A THING OF BEAUTY.
THAT BEING SAID.. YOU CAN STUFF A PRETTY GOOD SIZED TIRE UNDER A STOCK TRUCK. I LIKE TO PUT 315R16 RADIAL TRUCK T/As. THEY HAVE A 12" FOOTPRINT & FIT REAL WELL ON 8 OR 10" RIMS WITH 4" BACKSPACING. I'VE PUT THEM ON A 3/5 LOWERED SHORT BED WITH NO FITMENT ISSUES. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 09-16-2006, 12:21 AM   #15
72CSTC5
72CSTC5's Avatar
Hey pdr510 how low was your stepside with that kit on it. I have the same kit for my 2wd Blazer and I am thinking of taking it off of the frame and swapping it over to my 72 fleet truck.
72CSTC5 is offline   Reply With Quote
Old 09-16-2006, 09:16 AM   #16
pdr510
Junior Member
pdr510's Avatar
[/IMG]
The kit I had was 3" drop. You can add blocks to make it lower. Here is an old pic with the kit.
