Old 09-14-2006, 10:12 PM   #1
LawMan02
Junior Member
LawMan02's Avatar
Temperature gauge shows hot, truck not
I was ride around yesterday evening and looked down at the temperature gauge and it was pegged out as far as it could go to the hot side. Truck was running fine and showed no signs of overheating. I got home and shut the truck off and it stayed all the way over pass hot. I killed all the electrical current (main battery switch) and it never moved. Still that way this evening when I checked it and truck hadn't been run. All other gauges are working fine. Does anyone know what might have cause this and the fix? Thanks Randy
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust.
1973 Jeep CJ 5, 304, 33's with side pipes
2008 GMC 2500HD, CC, SWB, D/A, SLT
LawMan02 is offline   Reply With Quote
Old 09-14-2006, 10:17 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Temperature gauge shows hot, truck not
Check the wire going to your temp sender. It has probably feel against the exhaust or something
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 09-14-2006, 10:38 PM   #3
powell72
powell72's Avatar
If it's all the way pegged hot that means it's grounded out, follow the wire, you'll probably find the problem fairly easily.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-14-2006, 10:51 PM   #4
LawMan02
Junior Member
LawMan02's Avatar
Thanks guys. I will check it out tomorrow. It had me worried that the gauge might be messing up but now it sounds like a possible easy fix.
Old 09-15-2006, 02:22 AM   #5
Broken_down?
mine did that. wire had fused to manifold. rewired and never happened again.
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 09-15-2006, 09:51 AM   #6
byrd
Union Electrician
byrd's Avatar
Every now and then the resistor on the gauge goes bad and produces the same outcome.If the sending unit wire is not shorted out anywhere, the you should look at replacing the resistor.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-07-2006, 06:10 PM   #7
67chevemall
67chevemall's Avatar
That there is good to know.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-07-2006, 06:15 PM   #8
shifty
Questionable
shifty's Avatar
It's possible the sending unit could be toast too, right?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-07-2006, 11:03 PM   #9
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I'd say the wire is grounding out also. I had that happen to me. When my sending unit went bad my temp gauge stayed cold and didn't move at all.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-07-2006, 11:29 PM   #10
Richard H.
Spanked once
Richard H.'s Avatar
I have the same problem and mine is not shorted, where is the resistor you speak of?
Richard
Richard H. is offline   Reply With Quote
Old 11-08-2006, 07:49 AM   #11
byrd
Union Electrician
byrd's Avatar
on the back of the temp gauge. There will be a piece of wire mesh or porcelian between two of the studs, that is the resistor
Zip:40272
Old 11-09-2006, 08:48 AM   #12
67chevemall
Well I fixed mine. When switching over to 7 gauge dash I put the temp wire on the "now dead" oil (blue) line. oops.
Works good now thanks.
