Old 09-17-2006, 02:27 AM   #26
MisterMan
MisterMan's Avatar
Re: Best Gas tank for under the bed?
Originally Posted by big.mike View Post
Mine is being moved for 3 reasons.
1) 6'3 does not fit into a 5'8 cab very well
2) Being an audiophile, I have to have great sound, subs and amp are a must.
3) About 8 years ago I lost a friend who was a passenger in a 71 long bed that was t-boned. I won't go into details but my friend Barry was burned because the tank split due to the impact.
I have a MAJOR problem with having gasoline as the back of my seat. True that the tests have shown that it may be in an unsafe place but I'd rather lose my truck in an accident instead of my Son, Wife or myself.
Mike
agreed also.
MisterMan is offline   Reply With Quote
Old 09-17-2006, 12:48 PM   #27
jimmydean
jimmydean's Avatar
Originally Posted by classicchev View Post
I this in a lnog or short, If it is a long, buy a atank out of a 87 or so Suburban and plop here in . I have done it twice and it fits perfectly with no cutting. All I did was move the rea crossmember to the back and that was it.
I found a gas tank for an 87 that has the fuel pump in the tank. Do you use that too?
jimmydean is offline   Reply With Quote
Old 09-17-2006, 01:49 PM   #28
classicchev
classicchev's Avatar
The pump may have too much pressure if you are just using a carb. If its just a carb you are using, dont power up the pump. I had done a V8 TBI conversion in a S10 years ago, and got tired ofthe problems I was haveing so I put a carb on top and run it for 2 years without changing the tank.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 09-17-2006, 04:25 PM   #29
abadsvt
abadsvt's Avatar
WOW thanks for the responses! Is it possible to use or make a hidden hitch and move the gas tank to the back?
abadsvt is offline   Reply With Quote
Old 09-18-2006, 04:44 PM   #30
SactoJim
SactoJim's Avatar
Yes. That's how mine is set up. Another benefit of the hitch is the added protection to the fuel tank.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
