Old 09-20-2006, 03:21 PM   #1
Jimbotronics
YA YA
Jimbotronics's Avatar
Quick exhaust question
I have called serval muffler shops and they have no idea what I'm talking about, yet it's in the manual as being a factory set up.
I'm referring to the small flange extension that goes between the exhasust pipe and the donut. So you have the Ramhorn, then the donut, then the extension flange, the exhaust pipe. The PS was okay, but the DS was bent to all hell getting the old donut off off it (i think it was installed incorrectly). Anybody know what auto store carries these?
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 09-20-2006, 03:41 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Quick exhaust question
The only thing that comes to mind, is a short sleeve that fits inside the doughnut to keep from burning it out. If thats the case, we used a short lenght of 1 7/8" tubing , expanded (carefully) to the ID of the doughnut, then pressed into the 2 " tube. Hope that helps... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-20-2006, 08:39 PM   #3
orange-c10
www.lmctruck.com
orange-c10 is offline   Reply With Quote
Old 09-20-2006, 09:17 PM   #4
Jimbotronics
YA YA
Crazylonghorn - That's exactly it. How did you go about expanding the 1 7/8?
Orange-c10 - I looked through the LMC catalog (though I wouldn't think of ordering from them) - did you see something I missed? Only thing I saw that you could be refering to is a heat riser. Definitely not a heat riser.
Jimbo
'04 Chevy Avalanche
Old 09-21-2006, 01:37 AM   #5
jimfulco
Might try a Chevy place. We sold lots of them when I worked there years ago, and they might still stock them.
jimfulco is offline   Reply With Quote
Old 09-21-2006, 11:21 AM   #6
crazy longhorn
Most muffler shops should be able to build those pcs, the ones I have done were expanded & pressed on a pipe bender L
Old 09-21-2006, 11:47 PM   #7
Green Machine
Green Machine's Avatar
If you use the hard metal donuts you will not need the inner piece, but the soft ones will crust all to heck without the sleeve. I just use the hard metal gaskets and no leaks on three trucks and they are reusable too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
