Old 10-20-2002, 09:28 PM   #1
nroden
nroden's Avatar
HeadLights dont work
Well headlights aren't working now. The side lights and taillights are all comeing on. Fuses all look good in the fuse panel. The switch probably hasn't been on 15-20 times and isnt for the a year and 1/.2 old. The sealed beams are new. I am suspecting ground.... how are the headlights grounded. Thanks guys.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 10-20-2002, 09:41 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
check the dimmer switch on the floor...hit it with your foot a few times, they can cause odd things like that to happen....also make sure the wiring is plugged in.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-20-2002, 10:04 PM   #3
C-17RC-51
definately check the dimmer switch on the floor. I had the same problem. On mine the wiring harness by the switch was melted an the when i shook the wires the headlights came on. I also put new headlights in and the drivers side wasn't working after playing with the floor switch. I walked up front and tapped on the light and it started working. I think my harness on the bulb is AFU also. I'm going to rewire mine.
'70 C10 Longbed, 3-speed, 250 six banger surrounded by drums. Does it get any worse than this? Oh yeah... and I can see through the floor!
C-17RC-51 is offline   Reply With Quote
Old 10-20-2002, 11:18 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Your head lights are grounded directly to the rad support.
I agree about the dimmer switch. If kicking it don't help, then pull the carpet back, unplug it, and inspect the (probably) corroded terminals.
Old 10-21-2002, 12:30 AM   #5
cableguy0
the headlight plugs themselves like to crap out too. most auto parts stores carry new end to splice in. if they end up being the problem just use quality connectors and shrink sleeve to weatherproof the connection
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-21-2002, 01:09 AM   #6
Hooter
My other Love
Hooter's Avatar
there is a fusable link near the switch behind the dash I think because there was one on my 70 monte carlo. Took me along time to track it down. If no fusable link most likely the dimmer switch those things always crap out at the wrong time
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-21-2002, 08:01 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Check the passenger side top core support. Sand down to bare metal where it is bolted or screwed in and reconnect.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-21-2002, 09:22 AM   #8
guitarman
Do it well or don't do it
guitarman's Avatar
My vote the dimmer switch. They have them at Auto Zone for less than $4.00
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 10-21-2002, 11:33 PM   #9
nroden
nroden's Avatar
Got it fixed. Got a new dimmer switch at Lafaytte County Auto Center (NAPA) for $9.49. After I took it off and tried the new one I put the old one back on and it worked... even thought I had made sure everything was tight and hit it a couple times before. So I put the new one back on and will keep the old one for an emergency. It looked pretty corroded on its underside and on the terminals. I did go ahead and clean my ground before I bought the new dimmer switch.
Nick Rodenberg
