Old 09-25-2006, 11:36 AM   #1
Bowed
Axle Swap
If you put 91 suburban 10 bolt axles in a 76 blazer will the original drive shafts bolt up with out a problem ? Thanks .
Bowed is offline   Reply With Quote
Old 09-25-2006, 06:17 PM   #2
crossy
Oh,you can't buy that new
crossy's Avatar
Re: Axle Swap
no, at a bare minimum the rear u-joint will require the 'switch joint caue the cups on the pinion yoke are different sizes. It also requires careful measuring of the driveshaft. a 10 bolt driveshaft from blazer SHOULD be easy to find though.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
