Old 09-26-2006, 10:30 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Rally wheels dont fit
I got a set of 15X8 Corvette style Rallies for the front of my truck. I went to put them on and it looks like my calipers hit!!!!!! WTF
Anybody run into this problem? Is there a disc brake wheel and a drum brake wheel???
HELP, I already had the tires mounted
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-26-2006, 10:51 AM   #2
mkhutch
Throbbing Member
Re: Rally wheels dont fit
I ran into the same problem. I have seen some people grind the caliper down on the top edge to make it work. I ended up just going to a bigger rim.
mkhutch is offline   Reply With Quote
Old 09-26-2006, 10:59 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
OK, that doesn't sound cool at all. I just got a set as well. I checked the back for clearance, but no the front. Guess I'll have to see and maybe trim the caliper? Lots of people run these rims, wonder if they all had the same issue???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-26-2006, 12:54 PM   #4
mrein3
mrein3's Avatar
Yes there is a disc brake wheel and a drum brake wheel. Buyer beware!
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-26-2006, 02:40 PM   #5
1970 CST Short Wide
Senior Moment
I got the front ones for free; I guess I know why now. I will either grind the caliper, which I don’t really like OR get some wheel spacers which I don’t really like either but I have to get these wheels to work, at least for now
Pittsburg Ca
94565
Old 09-26-2006, 02:46 PM   #6
67ChevyRedneck
Crap, well, how can they be different? I mean, a 15" rim is a 15" rim right? Is it the backspacing that causes the problem? I guess I'll find out this weekend. I just had tires mounted on my rims this morning as well.
Jesse James
Project "On a Dime"
Old 09-26-2006, 03:25 PM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
There is a difference in drum and disk wheels!!!!!! My recomendation would be to sell the ones you have and buy the correct wheels!!!
72freak is offline   Reply With Quote
Old 09-26-2006, 04:00 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Not so much back spaciong, but general shape.
there is PLENTY of calaper material to remove, if it needs less than 1/8 inch, then I say go for it. I have done that much on later model stuff which we all know is generally made thinner than our old stuff.
Old 09-26-2006, 04:16 PM   #9
67ChevyRedneck
Thanks Andy! The reason I didn't check the fitment on my front rims was because I have 5 lug rotors on the front, decided to stick with 6, and my 6 lug ECE rotors are sittin in the garage waiting to go on the truck (no extra 6 lug rims with tires lying around so I had to wait 'till I got the new tires mounted.) Hopefully, they'll fit, if not, hopefully they'll just need tweaking!
Jesse James
Project "On a Dime"
Old 09-26-2006, 05:30 PM   #10
Longhorn Man
If you had your stock 6 lug rims, you'd find they don't fit either. 4X4 wheels will clear them though. Extra backspacing can solve the problem, but like I said before, it's the shape of the wheel in reality.
Old 09-26-2006, 08:03 PM   #11
QKENUF4U
QKENUF4U's Avatar
who did you get the rims from ? i still need to get mine for the front but sure dont need more problems mounting them like i did the back.
QKENUF4U is offline   Reply With Quote
Old 09-26-2006, 08:16 PM   #12
Fastfun
Fastfun's Avatar
The bolt pattern for a Corvette ,I think is 4-3/4" and the truck is 5". You can't use them unless you change to 4-3/4" bolt circle.
Fastfun is offline   Reply With Quote
Old 09-26-2006, 09:27 PM   #13
Longhorn Man
He has already gotten them over the lugs (and he stated they are 6 lug rotors) they are obviously aftermarket...but in the corevette rally 'style' wheel.
Old 09-26-2006, 09:34 PM   #14
jooooooe
The set on my truck are Vintage Wheel rally's, don't seem to have a clearance problem, they are 15x10's. I used 1971 spindles and calipers.
jooooooe is offline   Reply With Quote
Old 09-26-2006, 09:51 PM   #15
70short/step
70short/step's Avatar
It shouldnt matter disc or drum!
I have Wheel Vintques and they fit no problem. 5 lug ECE disc conversion. All the ralley wheels should be the same unless they ar 14" which you said they werent. depends on how much you have to grind on your rotor to make them clear is the only concern. If it is just a little then it is no problem.
ECE did say that i might have to grind a little on the caliper depending on which wheel I used.
I didnt see where you said if it is 5 or 6 lug or if it is a conversion. if it is stock then there must be something wrong with the wheel. If the are original vette rallies all corvettes with those rallies had disc brakes so the should fit.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 09-26-2006, 10:00 PM   #16
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
coloradok5.com has instructions for modifying a 3/4 caliper to run 15 inch wheels. The same process can be used for your problem.
low'n slow is offline   Reply With Quote
Old 09-26-2006, 11:11 PM   #17
jimmydean
jimmydean's Avatar
jimmydean is offline   Reply With Quote
Old 09-27-2006, 12:45 AM   #18
redhead69
fugedaboutit
redhead69's Avatar
since we are on the subject I am kinda worried now.. anyone know if I will run in to any problems with 15X8 6lug rallies on a drum/drum application? Its on a 67 frame, I just picked up some 4x4 rallies and was going to swap the front center cap out for another set of rears.. sorry to hi-jack btw
Currently truckless
redhead69 is offline   Reply With Quote
Old 09-27-2006, 12:55 AM   #19
corn
You are safe if you have drums. Ive got 4X4 rallies on my 69. I kinda wish I had the vette rallies though...
corn is offline   Reply With Quote
Old 09-27-2006, 01:06 AM   #20
redhead69
fugedaboutit
redhead69's Avatar
Cool.. thanks Cornfed. Thats a relief.
Currently truckless
Old 09-27-2006, 07:49 AM   #21
67ChevyRedneck
Originally Posted by jimmydean View Post
Sweet! Mine are the ones on the right!
Jesse James
Project "On a Dime"
Old 09-27-2006, 08:15 AM   #22
Are these the 6-lug aftermarket "Vette-style" wheels?I`m surprised they aren`t made with the modern "disc-type" profile.True,factory disc vs drum wheels are different.But,these "made for truck" car-style rallyes in 5 or 6 lug should be made in the disc profile.That`s nuts!
Old 09-27-2006, 08:24 AM   #23
powell72
powell72's Avatar
I was thinking the same thing. Why would a modern day wheel be made that wouldn't clear discs?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-27-2006, 10:03 AM   #24
1970 CST Short Wide
Senior Moment
Like I said, these were given to me so I don’t know the origin of them. I have stock disc brake spindles and its 5 lug. I'm looking for spacers to see if I can get it to work but will most likely buy new wheels that fit right.
Pittsburg Ca
94565
Old 09-27-2006, 10:07 AM   #25
67ChevyRedneck
Hey 1970 CST Short Wide: Do your rims look like the picture on the right or the one on the left (from jimmydeans post)? Just curious.
Jesse James
Project "On a Dime"
