Plate for the top of the rear coil ?
Hi all,
I'm replacing the coils on the back of my 72 GMC 3/4 ton, and the PO had done some questionable things to the rear axle (i.e. replaced U bolt with 2 regular bolts) ![]() Now I'm not sure if he removed the plates from the top of the rear coils, or if there weren't any to start with. Can someone help me out ? (Just to clarify, I'm talking about the plates that hold the bottom of the coil to the trailing arm. Where the top of the coil touches the frame there's only a bolt head sticking out...) Alberta Newbie |
#2 | |||
Union Electrician
Re: Plate for the top of the rear coil ?
it is called a spring cup I believe. There is one for the top and the bottom, bottom one has a nut welded to it and you just run the bolt up thru the trailing arm to catch the spring cup, and the top is a bolt and nut thru the frame and spring perch that holds the upper spring cup in place as well as the spring.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#3 | |
![]() Last edited by Aarons72s; 09-28-2006 at 01:54 AM. |
