Old 09-29-2006, 06:18 PM   #1
Crank
Crank's Avatar
73-87 Chevy Wiring Harnesses
OKay. I got this '86 GMC now. I kinda half way wanna do a frame off, quicky resto/custom, but I need a wiring harness that hasnt been butchered all up. I'm almost a little reluctant to go diving into this truck project without some sort of wiring solution. Does anyone know of an aftermarket replacement, such as painless, or anyone else that makes a harness for this truck, PLEASE HELP!!!!!
Brandon
Crank is offline   Reply With Quote
Old 09-29-2006, 07:07 PM   #2
C&C Chevy
C&C Chevy's Avatar
Re: 73-87 Chevy Wiring Harnesses
http://store.summitracing.com/partde...4&autoview=sku
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 09-29-2006, 09:47 PM   #3
Crank
Crank's Avatar
Okay, is this a direct replacement wiring harness or more less a generic harness you gotta add to to get right? is this the engine side and interior, and taillight and all or what? Thanks a lot.
Brandon
Old 09-29-2006, 11:02 PM   #4
C&C Chevy
C&C Chevy's Avatar
Staright from the link I provided.
Kits cover the following: A/C, heat, brake lights, coil, horn, electric fan, emergency flashers, dash instruments, headlights, radio (constant and ignition hot), turn signals, wipers, dome lights, third brake light, tail lights, charging, starting, power door locks, power windows, accessory plug, electric fuel pump, backup lights/cruise control, electric choke, and power antenna.
For 1967-72 GM trucks with factory A/C, an additional GMC/Chevy A/C harness (not included) must be used.
Click on the Install instructions also. It's in .pdf form at the bottom of the summit page.
Robert
Current:
Past:
Old 10-01-2006, 04:24 PM   #5
Mooshoo
I just ordered one for my 86 chev... it's a universal 12 circuit from headlight to tail light, includes engine compartment, steering column and under dash... everything... painless wiring cost me $750 canadian. had it overnight and then clip, clip, clip... a five year old could do it!
Mooshoo is offline   Reply With Quote
