Old 10-21-2002, 05:05 PM   #1
special70gmc
special70gmc's Avatar
axel gears?
i have a 4.10 rear 10 bolt stock rear. my truck is a 3/4 ton im tryin to figure out if its posi what do you think is it also its a 70 gmc 2wd
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 10-21-2002, 09:24 PM   #2
special70gmc
c mon i know some one can help me? but i also wanna know whats the best gers for some hwy mosly around town? 3.56?
1958 belair 2door
Old 10-21-2002, 10:06 PM   #3
crazy longhorn
Fabricate till you "puke"
Unless you go aftermarket, 4.10 is about as good as it gets on the corporate rear diff. I think some of the guys were talking about 3.90 & possibly a 3.73 ratio available.....but expensive. You could look around for a dana 60 with a 3.54 ratio, & swap it in to get a better all around gear. as far as posi unit, try jacking up the rear, & turn 1 wheel.....if the other turns the same direction, its posi.....if it turns backward, then its open. Hope that helps ....crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-21-2002, 10:19 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Crazy Al's right about limited options on improving your rear gears. Randy's Ring & Pinion www.ring-pinion.com makes a set of 3.90 gears, but your pockets will be empty . The best way to regear a 3/4 ton is to get a 14 bolt from salvage. Full floaters are readily available with 3.73 gears, a local yard told me that you can now get 3.42 gears, too. Someone else here said the 3.42 are only semi-floaters, so I'm not sure.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
